Clacking 350
Old Sep 6, 2014 | 08:41 PM
3wheelnuts's Avatar
Car: 91 TRANS AM GTA WS6
Transmission: T5 5speed
Clacking 350
Hi Guys, I'm stumped on this one. Got a L98 in my 91 Trans Am GTA and it makes a clacking on start up. Runs fine cold but after it warms up it makes a clacking noise when you give it a little gas and when you lightly let off the gas. It makes no noise on full throttle, idle or when you fully let off the throttle. I thought it might be the lifters so I replaced them, then I thought well maybe the timing chain so I replaced it. Now I am thinking maybe the distributor? It doesn't sound like a rod knock or it would do it all the time right? Could be wrong though. Just thought I would run this one by the forum before I pull the engine.
Thoughts?
Old Sep 6, 2014 | 09:30 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Re: Clacking 350
Exhaust leak?
Old Sep 6, 2014 | 10:27 PM
akanitro's Avatar
Car: 1989 GTA, 2004 Z06, 2008 Expedition
Engine: L98, LS3, 5.4L
Transmission: 700R4, MN6, Auto
Axle/Gears: 3.23, 3.42, ?
Re: Clacking 350
Check your flywheel bolts or for a cracked flywheel. I have seen that before. Also, what is your oil pressure?
Old Sep 6, 2014 | 11:02 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: Clacking 350
Thoughts?
have you correctly adjusted your valves? I do it this way ,buy the clips that go on the rocker arms,have the engine running at idle, back off each nut slowly till you get a clacking, then tighten them slowly just till the sound goes away, then go one full turn more and your done. doesent matter where you start or stop either.what you describe sounds to me like the valve train aint quite right.
Old Sep 7, 2014 | 08:54 AM
3wheelnuts's Avatar
Re: Clacking 350
Originally Posted by 8Mike9
Exhaust leak?
No, not an exhaust leak. It's more metallic.
Old Sep 7, 2014 | 08:56 AM
3wheelnuts's Avatar
Re: Clacking 350
Just swap in a 5 speed and it's still there. So flywheel is out. Oil pressure is at 30ish idle and 55ish while driving.
Old Sep 7, 2014 | 08:58 AM
3wheelnuts's Avatar
Re: Clacking 350
I would have to agree, however, I did replace the lifters and re-adjust the valves according to the book(not running) and the noise is still there. I could try the running method though.
Old Sep 7, 2014 | 09:00 AM
3wheelnuts's Avatar
Re: Clacking 350
The flywheel thing gave me a thought. I'm gonna look for a loose bracket or something. I'll keep you guys posted.
Old Sep 7, 2014 | 11:11 AM
Car: 86 IROC
Engine: 5.0 TPI
Re: Clacking 350
doing it with the engine running lets you adjust them in "real time" .and you get a much better end result.
Old Sep 8, 2014 | 09:46 PM
BASSETT IROC 85's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
Re: Clacking 350
Did changing lifters change the noise?
Old Sep 9, 2014 | 07:48 AM
3wheelnuts's Avatar
Re: Clacking 350
I'll give it a try. Couldn't hurt.
Old Sep 19, 2014 | 08:05 AM
3wheelnuts's Avatar
Re: Clacking 350
Well, turns out it is a rod knock.......That's what I figured but I was hoping. Oh well, time for a new crank...
Old Sep 19, 2014 | 08:29 AM
Car: 86 IROC
Engine: 5.0 TPI
Re: Clacking 350
no hold on a minute, if it aint knocking bad you can re use the crank AFTER you have it turned and sonic checked. but I always toss the rod on the knocking cyl.
Old Sep 19, 2014 | 08:38 AM
3wheelnuts's Avatar
Re: Clacking 350
Yea, I'll have the crank turned and cleaned up. The rod will get pitched...no reason to take a chance on that.
Bubbajones_ya
Jul 6, 2024 08:32 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
FormulasOnly
Sep 10, 2015 09:07 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Formula_88AE
Sep 3, 2015 01:47 PM
