Plug wires?
Car: 82 Z28
Engine: 370 ci.
Transmission: M 20 4 speed
Axle/Gears: stock open 3.43
Plug wires?
I just finished putting the motor back in my car and the plug wires don't work the long tube headers. Can anybody recommend a good set of build your own length wires? Or a set that works with long tube hookers and straight plugs. The last set of build your own wires I used were garbage. Don't want to go through that again. Thanks in advance.
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
Re: Plug wires?
http://www.scottperformance.com/home.htm His wires are custom fit, no need to build them. But if you want to build your wires he has them too.
Engine: 4++,350 & 305 CIs
Re: Plug wires?
I like Taylor wires.
Car: 82 Z28
Engine: 370 ci.
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Car: 82 Z28
Engine: 370 ci.
Re: Plug wires?
Thanks guys. I like the magna core site. Pretty informative. I am going to talk to both of them.
Car: 86 Trans Am WS6
Engine: 383 stroker
Re: Plug wires?
I bought an accel kit that I was pretty happy with till I burnt one, pretty cheap on jegs
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Plug wires?
I use Taylor or Accel universal wire sets with 90-degree plug boots.
The time consuming part of fitting your own wires is the stripping and crimping operation.
For stripping, I use one of these stripping blocks. You use it with a single edged razor blade. It'll cut through the outer and inner insulation but won't nick the center core:
http://www.jegs.com/i/Taylor/895/43395/10002/-1
For crimping the terminals I use a Mallory crimping tool:
http://www.jegs.com/i/Mallory/650/29085/10002/-1
eightsixseven
Dec 16, 2024 01:50 PM
