383 fouls plugs
Car: 86 IROC-Z
Engine: 383 Stroker Vortec
Transmission: 700r4 Built
Axle/Gears: 3:42
383 fouls plugs
fresh 383 maybe 10 miles on it keeps fouling plugs , I know the carb needs to be tuned better any other things that would cause this
Posted from Thirdgen.org App for Android
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: 383 fouls plugs
Too cold a plug? It sounds like a tune issue if it hasnt been tuned yet. If plug is black and smells of fuel or even wet with fuel its likely too rich which will kill a plug quick
Car: 86 IROC-Z
Axle/Gears: 3:42
I was told I had some of the hotest plugs, but I can tell by my eyes burning it runs way to rich
Car: 1991 camaro rs
Engine: 496 big block
Transmission: th400
Axle/Gears: stock rearend. 3.23
Re: 383 fouls plugs
adjust your mixture screws all the way in towards the carb and back them out 2 1/2 turns out and start with that
1. what size carb do you have
2. what kind of carb are you running
3. what kind of ingition are you running stock HEI wit stock coil, if so for starters get a better coil hei's are fine but anything bigger than a 350 needs abigger coil for a better burn with more fuel
Car: 92 Camaro RS
Engine: 355, Vortec heads, XE274 cam, 9.8-1
Transmission: 700r4 built for 800-900hp
Axle/Gears: 3.73 Gov Lock, Soon to change
Re: 383 fouls plugs
What is the fuel pressure to your carb?
Car: 89 IrocZ
Engine: L98-ish
Re: 383 fouls plugs
Real rich is bad on a fresh engine, suggest you look into a properly sized carb and jets...many put on a big carb and wonder "why does it not run faster?"
Aside from that, let us know what rings you used, i/e CrMoly rings take some time to seat...could be oil fouled...could be other things but "carb'ed 383 fouls plugs"...isn't a lot to go by
