cross brace in front of radiator needed?
Old Sep 14, 2014 | 01:21 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Hey guys,
I have these two cross braces that cross in front of the radiator. They are just two light bars that bolt on each side of the front of the radiator and make a "x". Do I Need them or not? Can't properly mount my aux trans cooler with them there. Thanks for any help!
Old Sep 14, 2014 | 01:28 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: cross brace in front of radiator needed?
Originally Posted by Ozz1967
Hey guys,
considering the flexable nature of our cars. they need all the help they can get , so yes they are needed. and yes there is no problem mounting a trans cooler to them
Old Sep 14, 2014 | 01:32 PM
gt4373's Avatar
Transmission: 5-Speed Manual
Don't Remove Any Supports.
Old Sep 14, 2014 | 02:28 PM
Ozz1967's Avatar
Car: 1984 Trans Am
They're just preventing me from mounting the trans cooler to the radiator, they're in the way. I'm going to have to see if I can use some zip-ties and mount it to them instead I guess.
Old Sep 14, 2014 | 02:55 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Is your cooler to thick to fit behind them?
If not, take them loose, mount cooler, put them back on...took a look at my car, appears to about 1.5 inches of space.
Old Sep 14, 2014 | 02:57 PM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
I gave you my pics installed behind the braces and attached to them. Whats the issue? Cooler too thick?
Old Sep 14, 2014 | 03:41 PM
whatever84's Avatar
Car: 84 Camaro
Engine: 357
Transmission: TH350
Axle/Gears: 4.10's / Strange LSD
I mounted my cooler to the braces, works fine.
Mark.
Old Sep 14, 2014 | 04:05 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Did you send me pictures or have a link for it?
Old Sep 14, 2014 | 04:34 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Not I, I had just looked at mine, and there appears to be 1.5 inches of space between the bars and condenser.
Old Sep 14, 2014 | 05:40 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Here it is, zip tiredbto the cross bracing.
Attached Thumbnails cross brace in front of radiator needed?-img_20140914_163433.jpg   cross brace in front of radiator needed?-img_20140914_163438.jpg   cross brace in front of radiator needed?-img_20140914_163348.jpg
Old Sep 14, 2014 | 05:41 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Yes, the cooler is too wide/long/thick to fit around or under the bracing.
Old Sep 14, 2014 | 06:25 PM
Restrorob's Avatar
Car: 88 GTA
Engine: Built 355 to install
Transmission: Built turbo 350
Doe's my 88 GTA supposed to have these cross braces ?
I see Classic has them listed, but I see no holes to mount them on mine.
Old Sep 14, 2014 | 07:18 PM
Ozz1967's Avatar
Car: 1984 Trans Am
I don't know?
There are just four bolts, 10mm, one for each end. Top and bottom on each side of the radiator about where you see them terminate there.
1992 Trans Am
May 10, 2023 07:19 PM
IROCZ1989
Jan 24, 2016 03:55 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
