Turn signal switch adjustment and lever removal
Old Sep 15, 2014 | 03:03 AM
Redsome's Avatar
Car: '91 Pontiac Trans Am
Engine: 305 TPI (LB9)
Transmission: Manual, 5 spd.
Hello,
Does anyone know how to adjust turn signal switch and also how to remove the lever? Switch is out of place and I get no click when I pull it back to dimm headlights so adjustment is needed and the lever is in bad condition as well so I'd like to replace it at the same time.
Plastic cover around the switch is in one piece and to remove it I'd need to remove steering wheel first which... So... With that plastic cover on, can I remove the lever and adjust the switch? Can anyone point me in the right direction?
Thanks.
Old Sep 15, 2014 | 06:24 AM
Re: Turn signal switch adjustment and lever removal
There's no adjustment.
Gotta pop the steering wheel off. Most likely you'll need to replace the turn signal switch.
Be REAL careful with the parts related to the horn; most of the time, you can tell a car that somebody has had the wheel off, because those parts are tore up. The plastic piece that the yellow wire comes through, locks in there like a light bulb. Push it in, turn it a quarter turn, it'll come out. If you just yank it out, the horn won't work again until you replace it.
Old Sep 15, 2014 | 04:19 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
The lever and turn signal switch are separate parts which you'll have to purchase separately. Again, the turn signal switch has no adjustment.
The dimmer switch is attached to the steering column down towards the firewall. There's a rod that travels from the lever down the column to the dimmer switch. There's some adjustment at the switch; loosen the mounting screws and you can move the switch up or down the column.
Old Sep 16, 2014 | 12:34 AM
Redsome's Avatar
I see, thanks! The adjustment of dimmer switch is exactly what I need. I tought dimmer switch and turn signal switch are one and the same but now I know better. And where are those two mounting screws? I think I have a cover plastic missing becouse I can see wires comming from the turn signal lever to the connector under the column height adjusting lever and no screws are seen there. But the whole pice is very loose. If I hold it tight against the column and move the turn signal lever towards me I can hear click and the lights go from low to high beams. But if I don't hold the plastic then that plastic moves freely and there's no click... So I somehow need to fixate that piece of plastic to which (I assume) the dimmer switch is attached to.
Old Sep 16, 2014 | 06:24 AM
The dimmer sw IS adjustable. It's right above the brake pedal, on top of the column.
Sounds like that's not what's wrong though; the problem with working that, is that the lever is loose on the turn signal switch. Most often that's because the TS sw is wore out.
Gotta pop the wheel off to fix it.
Old Sep 16, 2014 | 07:13 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
if your tilt mechanism is loose it will affect proper actuation of the dimmer switch. if this is the case, tighten the tilt screws in the column and all will be well.
Old Sep 29, 2014 | 05:51 AM
Redsome's Avatar
So, I found the dimmer switch and push rod. Now I'm trying to find mounting screws on that switch so I can push it up (towards the push rod) a bit but I can't find any screws down there... Any further help on how to adjust the switch would be greatly appreciated.
Caspar
Jun 19, 2016 11:19 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
3rdgenparts
Aug 8, 2015 07:09 PM
