Should replace valve seals during head gasket change? 89 350 TPI
Old Sep 21, 2014 | 10:20 AM
214jay's Avatar
Car: 1989 Pontiac Firebird Formula 350
Hello. I am new to the inner workings of the SBC but have the heads off to check/replace the head gaskets.
I know I need to setup the valve lashing but should I be looking to replace the valve seals? I would rather not if it is not needed but someone more familiar with these engines has told me to do it!
Jay
Old Sep 21, 2014 | 10:42 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Should replace valve seals during head gasket change? 89 350 TPI
an ounce of prevention can be worth MANY , MANY pounds of cure . they are cheap , easy to do , why not ??? a good cleaning of heads and new seals just makes good sense . my personal choice would be new stem seals and new umbrella seals on ALL valves . do it once , do it well , do it right . you will be happy . good luck ..............
Old Sep 21, 2014 | 10:49 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
^^^^^^^^^^^^^ Good advice.
Old Sep 21, 2014 | 11:13 AM
214jay's Avatar
Great thanks for the advice, its the first time I will have removed the valves (on any car) but fairly sire I know the process. Only question is I can only find the Stem Seals listed on RockAuto and there seems to be a massive choice, where do I start with knowing which ones suit the vehicle?
Old Sep 21, 2014 | 11:46 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
you want the kind that fit down over the guide,rather than the ones that merely ride up and down on the valve stem.
Old Sep 21, 2014 | 03:13 PM
214jay's Avatar
Right, okay thanks. Will do more research as theres loads of different sizes for my car.
Old Sep 21, 2014 | 08:19 PM
tyeo098's Avatar
Car: 88 Chimera
Engine: 1994 LO5 5.7L
Axle/Gears: 2.73...?
What exactly caused you to take the heads off now?
Compression check give you leaky adjacent cylinders?
Old Sep 21, 2014 | 08:48 PM
BASSETT IROC 85's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
I have seen several 1989 and 1990 chevrolet 350 blow the head gaskets. I always have the heads resurfaced and rebuilt. The last one I did has lasted over 18 years so far.
Old Sep 22, 2014 | 12:43 AM
214jay's Avatar
Bit of a long story but suspected engine had sucked in a rag so bit of a checkup required! All looks okay, have checked heads and they are not warped or cracked so going to fit some good head gaskets and put them back.
Just not sure which seals are appropriate, I will pull one of the valves and have a look.
Old Sep 22, 2014 | 07:09 AM
torque_is_good's Avatar
the economy is still stinky so you could probably find a machine shop who would do a valve job on the cheap incl parts, testing springs, checking head, cleaning and if it's not been done, new guides as well.
But, if your wallet is real thin, at least lap the valves and put in new seals
Old Sep 22, 2014 | 07:13 AM
214jay's Avatar
Would prefer to do myself as I'll learn for the future that way. Based in the UK and not many machine shops I trust around here!
Old Sep 22, 2014 | 07:57 AM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
If the heads are off, I would do as much as possible while you have the opportunity. If you want to upgrade springs, valve job, etc.
Once those heads go back on, you don't want to say "I wish I would've ______ when I had those heads off".
Just my 2 cents.
Hope this helps!
Old Sep 22, 2014 | 02:00 PM
tyeo098's Avatar
Car: 88 Chimera
^this because once you torque those heads on the gaskets become useless for reuse!
For what its worth I plan on doing the same on my LO5, gonna remove the heads, port 'em upgrade all the moving bits and put new valve seals on (leaking oil somewhere)
Gonna put new headgaskets on as well and see what kind of condition my holes 'n' rods are in.
Old Sep 22, 2014 | 04:08 PM
kudos for wanting to do things yourself.
Since you yanked the heads, you now NEED new head gaskets and possibly bolts
You also need a new intake manifold gasket and since the distributor is out, give it a good once over.
Now come the options
if it's never been done, at this point, I would inspect the lifters (if roller) and replace if flat tappet. Next is checking the pushrods
OK, now to the heads themselves. Again, if it's aged, then new guides are in order. Are the valves re-usable? At a minimum, lap the valves but a machine shop can clean the heads, (probably cast) magnaflux checking for any cracks and mill them. A machine shop can also check the springs
How are the rockers? Maybe it's time for a poor mans upgrade and go for some 1.6 ratio (if you have 1.5) but your springs will again determine that
or, just check the cylinder ridge and make note as to how bad it is/isn't
slap on a new gasket, lap the valves, slap on some new seals and run it til it breaks
Old Apr 27, 2017 | 07:52 AM
milhouse89's Avatar
Car: 1989 Camaro I-ROCZw/T-Tops
Engine: 5.7L
Transmission: 700-R4
It's been awhile but maybe you can help me. I am interested in what head gaskets and intake manifold gaskets and also valve seals you used and how they worked out for you. Like you said with the valve seals there are a lot of choices. I've got the same engine as you but with Al. heads and I would like to get it right. Thanx for any help , I hope you get this soon.
Old Apr 28, 2017 | 02:36 PM
214jay's Avatar
Hi Milhouse
I didn't do the valve seals in the end as I ran out of time, I have had no problems at all though and to be honest wasn't that hard to take the heads off and put back on so its on a future list when I do more major engine work.
I used the following gaskets/parts to put the engine back together:
Upper Plenum FEL-PRO MS93160
Cylinder Head Bolts FEL-PRO ES72856
Cylinder Head Gasket FEL-PRO 7733PT2
Rocker Cover Gaskets (these are excellent, great reusable gasket) FEL-PRO VS50088R
Intake Manifold Gasket (think this was the one) MAHLE ORIGINAL/VICTOR REINZ MS15315W
All of the above were from RockAuto and I have had no problems with any of these products, even 2+ years later. Hope this helps in some way!
J
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
NBrehm
Aug 25, 2015 11:49 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
