84 Camaro Surging, random low idle, bogging
Old Sep 28, 2014 | 01:32 PM
jordanjk123's Avatar
Hey guys, this i my fist post. I just recently got an 84 camaro with a 350 swapped into it. Some days it runs like a dream. Other days it will be difficult to start, where i have to hold the gas to the floor and crank it over quite a few times. Also sometime if i am trying to hold a constant speed it with surge forward and sort of sputter a little. The other day it got really bad, idling down to 600 rpms, super bad bogging, bouncing back in forth in my seat it was so bad. And today it runs fine. I already replaced the fuel filter. And plugs and wires are good. Help!! Thank you!
Old Sep 28, 2014 | 01:57 PM
MikeMN's Avatar
Car: 1988 Trans Am GTA and 1979 10th Anv
Re: 84 Camaro Surging, random low idle, bogging
I had similar issues, it ended up being the pick up coil.
Old Sep 28, 2014 | 02:01 PM
Is there a way to test the pickup coil to make sure?
Old Sep 28, 2014 | 02:06 PM
MikeMN's Avatar
Ohm meter, should be between 500 and 1500.
Mine was reading 455, plus once I looked at it further and removed it this is what I found.
Old Sep 28, 2014 | 02:13 PM
okay, so this is under the distributor cap? I'm having troube finding a good tutorial.
jklein337
Sep 19, 2018 06:23 PM
Infested
May 22, 2018 11:56 PM
Andrew6.688
Dec 13, 2015 10:59 AM
perZ
Aug 15, 2015 01:17 PM
