400sbc rebuild
Old Oct 5, 2014 | 05:45 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
400sbc rebuild
After 4 years of spraying nitrous to my completely stock shortblock(virgin bore,cast pistons 22 dish, stock 5.565 rod, stock 3.75 crank, 9-1 compression) the bearings are shot.
It chewed the crank bad enough that I can't reuse it. It just started to mark the rod bearings.
So a buddy of mine is giving me his stock rotating assembly from his 400, (exactly same as mine)
I was going to put new bearings and rings and giver again for 1 more year. I also have ARP main studs to help with some more strength. I also have the 330817 2 bolt block.
Then in the fall of 2015, I will have saved enough money to get a SHP block and go 421sbc with all forged internals.
So, my question is should I align hone before I putting the rotating assembly back in?
Should I get some 5.7 rods and new (hyper) flat top pistons or is this a waste of money for 1 more point of compression and slighty better rod?
Would I have to balance that new rotating assembly?
New pistons are $240 from summit and give me 10.5 compression. I could probably get some 5.7 rods for free
Thoughts?
Old Oct 6, 2014 | 11:39 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: 400sbc rebuild
Thoughts?
NOS on stock internals ALWAYS makes a nice BOOM! to run it you need forged internals,a balance & blueprint. as for the pistons from summit, if they are cast, they wont take it. unless the NOS is something rediculas .like a 50 shot. I assume you go bigger.
Old Oct 7, 2014 | 09:35 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Re: 400sbc rebuild
For the last 2 years I have been spraying a 125 shot.
The engine didn't go boom, just a knock, lol.
Old Oct 7, 2014 | 11:37 PM
Car: 86 IROC
Engine: 5.0 TPI
Re: 400sbc rebuild
man,,, jesus must love you! usually, a 100 shot makes shrapnel. the fact is this .cast aint gonna last. you endanger everybody at the track around you trying to go big with stock stuff. but hey, its your game.
Old Oct 8, 2014 | 09:13 AM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Re: 400sbc rebuild
This unfounded conclusion can only come from the experiences of people who have no understanding of nitrous, what to do, what not to do, and how to tune for it. I've been running 150 shots on stock bottoms since 2002 and haven't hurt one yet. I've worn out engines, but no outright failures with nitrous.
Old Oct 13, 2014 | 09:40 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Re: 400sbc rebuild
Agreed.
I had personally seen guys at my track spray 200hp on a stock engine just with a hyper piston change!
SO, back to my original question!
Should I align hone before I putting the rotating assembly back in?
Should I get some 5.7 rods and new (hyper) flat top pistons or is this a waste of money for 1 more point of compression and slightly better rod?
Old Oct 14, 2014 | 06:00 AM
86LG4Bird's Avatar
Re: 400sbc rebuild
Since you say you'll be going with an all new motor a year from now, I wouldn't mess with any of it. Just drop that rotating assembly in with new bearings, checking all clearances of course. If his crank is straight, the mains will hang in there just as well as they have till now.
Don't use the main studs unless you do decide to align hone.
Old Oct 14, 2014 | 08:20 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: 400sbc rebuild
Thats what i am thinking. Throw it in and run it for the year. Get by until 2015, put all your money into that build
Old Oct 14, 2014 | 06:42 PM
HINKSON AUTO's Avatar
Re: 400sbc rebuild
With any GM block that has been through many heat cycles its best to line hone if your rebuilding and more so if adding a stud kit.
400 blocks required the rear seal area to be line bored and you need a 2909 Felpro seal.
Old Oct 14, 2014 | 10:25 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Re: 400sbc rebuild
It's about $150 for an align hone.
So is it better to go with main bolts or get an alignment and use the studs?
Old Oct 14, 2014 | 11:30 PM
Night rider327's Avatar
Car: 1988 Camaro
Re: 400sbc rebuild
Of course it's better to use the studs and have the mains line honed, BUT if your building bigger/better in a year for sure, then why waste any money on this one.
Drop it in and go, put the amount you saved into a savings fund for the new engine build.
Old Oct 16, 2014 | 10:49 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Re: 400sbc rebuild
Thanks for the info guys.
Another question?
What grit number should I use for a hone stone?
240?
Old Oct 17, 2014 | 08:51 AM
big hammer's Avatar
Car: 2002 ws6, 2011 sierra 6.2L 6 speed
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
Re: 400sbc rebuild
I ran a 125 shot on my 400 bottom end with no issues. stock crank and rods with forged pistons.
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
hartsmike
Oct 2, 2015 07:11 AM
Derrick86
Oct 1, 2015 05:12 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
3.8TransAM
Sep 27, 2015 08:37 PM
