86 z28 looses all power for a second or two while driving engine also turns off
Old Oct 11, 2014 | 01:36 PM
wranglaro86's Avatar
Car: 1986 camaro z28
Engine: gm goodwrench 350 300 hp
Transmission: 5sp
Axle/Gears: stock
hi everyone my car will loose power to everything while driving and engine will also shut off sometimes or it will just bog down for a second could a short be causing this or a loose connector on a fuse box? battery cable are tight
Old Oct 11, 2014 | 08:34 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Re: 86 z28 looses all power for a second or two while driving engine also turns off
Do you lose headlights when it does this?
Old Oct 11, 2014 | 09:04 PM
Transmission: 5sp
Axle/Gears: stock
Not that I know of but my hazard lights did not work when I pulled to the shoulder one time. What would the difference be?
Old Oct 12, 2014 | 10:43 AM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
This would rule out the main battery connections. I'm assuming this is a carbed engine? I'd put a small lamp/light inside the car and wire it to the 12v coil feed to start with, make sure it's getting voltage. Electric fuel pump? Factory pump might have a relay going bad, I'd next hook the light to the main wire back to the pump. Go through all the things that might be going open or losing voltage. Wondering if it could be vapor lock in the fuel line too.
Old Oct 12, 2014 | 10:50 AM
Transmission: 5sp
Axle/Gears: stock
yes it is a carb caris has a new 350 in it from the 305 that was in it beforeswapped out and use the same fuel pumpit's attached to the block and I believe its just mechanicalyou mention vapor lock in the gas line but how would that relate to losing all power
BRoss99
Aug 10, 2025 05:08 PM
specialized
Jun 18, 2022 09:26 AM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
novaderrik
Aug 10, 2015 12:44 PM
