Lifter tapping when hot?
Old Nov 9, 2014 | 01:42 PM
86purpledragon's Avatar
Car: 1986 Trans Am
So I'm having a problem with my 350. Its got about 15000 miles on it after a bottom end build, heads were not rebuilt. It has full roller rockers, comp extreme energy hydraulic flat tappet cam & lifters, scat forged crank, edelbrock intake and carb. It has a couple known problems;
-Passenger side header has a small leak that I can't find
-Valve stem seals are going bad (smokes on warm restart after sitting for a bit)
-Carb is on its last leg, inside of it has started corroding so it runs rough sometimes till I clean it
But I have been limping it along with these problems, just keeping an eye on things. Now it has developed a new problem. I noticed a tapping on the passenger side head, so I adjusted the rockers to 1/4 turn past zero lash thinking one had loosened. This didn't fix it though. The tapping sounds like its just one rocker. The strange thing is it only starts to tap after the engine has warmed up. So completely cold, there is no sound, but as soon as I let it warm up or rev it a little bit it starts to tap.
Now this sounds to me like a problem lifter, but I not 100% on it. Does anyone else have any ideas? Am I wrong on this diagnoses? I put some seafoam in the oil today and plan to change the oil next weekend after driving it a bit to see if its gummed up. Any input is much appreciated, thanks.
Old Nov 9, 2014 | 03:03 PM
big hammer's Avatar
Car: 2002 ws6, 2011 sierra 6.2L 6 speed
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
Re: Lifter tapping when hot?
How is your oil pressure when it's ticking?
Old Nov 9, 2014 | 03:23 PM
Car: 1986 Trans Am
Oil pressure when cold is pegged at 60, once warm it drops to about 35. It will tap before the pressure drops, just not on initial startup. I've noticed that if I give it a couple small revs right after startup, sometimes it will start tapping.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Thaney9
Oct 24, 2015 07:26 PM
skinny z
Oct 5, 2015 06:23 PM
mfp189
Sep 27, 2015 09:25 AM
ironbmt
Sep 27, 2015 06:00 AM
