need help
Old Nov 16, 2014 | 01:08 PM
kyblackss's Avatar
need help
i just put my tpi back on my 85 camaro its been off for years so i put a new aem fuel pump and some used lt1 injectors on it and it will not start cranks good and will hit on starting fluid any input would be appreciated
Old Nov 16, 2014 | 03:30 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Re: need help
I'd responded to a similar issue yesterday:
https://www.thirdgen.org/forums/tpi/...ue-cranks.html
Old Nov 16, 2014 | 04:09 PM
kyblackss's Avatar
Re: need help
i deleted the cold start but didnt reflash the computer for it do you think that could be it has plenty of fuel pressure
Old Nov 16, 2014 | 05:39 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Re: need help
If you have verified fuel pressure and we know you have spark (via starting fluid), then the injectors are not firing (or getting signal to fire)...or if they are, then they are plugged up.
Old Nov 17, 2014 | 08:48 PM
kyblackss's Avatar
Re: need help
i went and got a noid tester today will check the injectors tomorrow
Old Nov 17, 2014 | 09:11 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Re: need help
Remember, the noid light will tell you if the ECM is trying to fire the injectors...one side should flash when the engine is spinning over.
Let us know.
Old Nov 18, 2014 | 04:20 PM
kyblackss's Avatar
Re: need help
it has 50 psi when cranking and the noid light is flashing real good tried 3 different injectors and the noid light flashed on all of them
Old Nov 18, 2014 | 09:16 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Re: need help
My best guess, is the used injectors are clogged, plugged up...if you have fuel pressure at the rail, and the signal to fire the injector is there...what else could it be? (asking, surmising)
Old Nov 19, 2014 | 07:54 PM
kyblackss's Avatar
Re: need help
i will put another set in it and let you know
Old Nov 20, 2014 | 06:55 AM
southbay08's Avatar
Re: need help
sometimes you can luck out with used injectors functioning properly, however it depends on how long they were sitting and what condition they are in.
Old Dec 7, 2014 | 07:47 PM
kyblackss's Avatar
Re: need help
well just got to working on the car again changed out the injectors and still no luck tries to hit but still no start and the engine light stays on
Old Dec 9, 2014 | 01:43 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Re: need help
Were these new injectors this time?
Old Dec 9, 2014 | 07:23 PM
kyblackss's Avatar
Re: need help
Nope another used set
Old Dec 9, 2014 | 10:26 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Re: need help
Feeling a common denominator here..
