re - using roller lifters after tornado
Old Nov 18, 2014 | 01:57 PM
lewandom's Avatar
Car: 84 Z-28 Camaro, 2022 Chevy 2500
Engine: 383
Ok I haven't been on the boards in a very long time, I've been busy with work, but anyway, I am re building my camaro after it was severely damaged in the April 27th tornado, it was one of the few things I had that wasn't completely blown away, but before the tornado I had the intake and heads off and the lifters were exposed to the elements for 6 months after the tornado, the ones that were raised in the bores had some slight surface rust but looked otherwise undamaged, the rollers look fine, I am more worried about the internals as the whole lifter valley was full of house insulation (the shredded paper kind, that's what they used in our house)...what do u guys think.
Old Nov 18, 2014 | 02:03 PM
92GTA's Avatar
Re: re - using roller lifters after tornado
Sounds like bad news, moisture, surface rust everywhere, it will only be worse inside where you can't see it. I really hate to say it but I think the whole thing needs to come apart for a proper cleaning :/
You should be able to re-use them if you hit them really well with an emery cloth. Otherwise get new ones so they don't wipe the bores. Considering you aren't even supposed to mix lifters into different bores, I wouldn't chance it.
Old Nov 18, 2014 | 02:32 PM
lewandom's Avatar
Engine: 383
Sorry forgot to mention, the engine is a 550 hp 383 full roller, and I'm already having the whole bottem re - done due to the fact that the oil pan was completely full of rainwater, I'm trying to keep costs down as insurance didn't cover it, we kept the lifters marked so they will go back in the same bore, I'm more worried about the lifter innards than anything ells, if I can fig out how to shrink pics I'll post them, I have about 20 or so
Old Nov 19, 2014 | 01:00 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Should be able to take the lifters apart and have a look.
Old Nov 19, 2014 | 03:06 PM
lewandom's Avatar
Engine: 383
Never taken a lifter apart...they are comp roller retro conversation lifters. Somebody have detailed instructions?
Old Nov 19, 2014 | 03:12 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
yes. disassemble the lifters, clean and re-use. or hit the JY for another set from a motor that looks clean and hasn't been opened to the elements. they may look good on the outside but the innards can gum up.
Old Nov 20, 2014 | 01:22 AM
DeltaElite121's Avatar
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
He can't do that. Using retrofit lifters. I would ask comp if you could send them in for inspection and a rebuild personally. Not worth risking a huge failure over a relatively small price.
Old Nov 20, 2014 | 06:54 AM
naf's Avatar
naf
missed that thanks. would definitely not re-use without though without someone inspecting and/or cleaning them. I've run into gummed up lifters that looked fine on the outside.
Old Nov 20, 2014 | 11:03 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Delta nailed it...that'd be the prudent thing to do.
Old Nov 20, 2014 | 01:05 PM
FRMULA88's Avatar
Car: 1988 Formula
Engine: 421 Little M block
Transmission: TH400 w/brake
Axle/Gears: 9" 4.30s, Wilwood discs, 28X10.5-15
Any internal engine components exposed to the elements, dirt, etc. should be cleaned, dis-assembled, inspected, cleaned, re-assembled, and cleaned.
Did I mention the parts should be cleaned?
If in doubt replace them with new.
Old Nov 21, 2014 | 12:39 PM
lewandom's Avatar
Engine: 383
I'll contact comp, hopefully they can do somthing with them, it's close to 5 bills for a new set, also dose anyone know how to shrink the size of pics with an Android, I lost my computer in the tornado, I have pics of the damage to the car, but they are all like 2 meg and no clue how to change them w my phone
Old Nov 21, 2014 | 03:05 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Upload them to photobucket. Get their app and it will auto resize them.
Old Nov 22, 2014 | 04:03 AM
lewandom's Avatar
Engine: 383
<iframe width="480" height="360" src="http://s48.photobucket.com/user/lewandom/embed/slideshow/"></iframe> ok...that's 3 pics... I have like 20 total..If it worked give me a heads up and I'll post the rest, and the tornado pic is one my flight instructor took while it was in Mayflower, ar
KO1
16
Oct 15, 2015 05:00 PM
skinny z
Oct 5, 2015 06:23 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
