Oil&Temp indicators
Car: 1989 Gray ttop GTA
Engine: 5700cc
Transmission: auto 700R4
Oil&Temp indicators
Hi
This is a trivial topic. I have those parameters in my GTA in normal-running conditions. Are they correct? What is the oil indicating, pressure?
THANKS!!
THANKS!!
Re: Oil&Temp indicators
Yes, the oil gauge indicates oil pressure in PSI (pounds per square inch). Temp gauge is in degrees F. If the engine was warmed up and just sitting there while idling, I'd say these indications look normal. Oil pressure will (should) increase when RPM's increase. Temp may increase while sitting at a prolonged idle, too.
Ideal operating temp is around 195 -200 degrees F. However, an analog gauge is not an absolute indication.
Engine: 5700cc
Thanks guys!!
That pictures was with warmed up engine and idle. If I accelerate hard, pressure goes to 40psi, maybe less more. Should be reach 60?
thanks
thanks
Also, after the engine warms up, the oil thins out somewhat from a cold state. You will probably see higher oil pressure when it's cold as opposed to being warm.
Car: 1987 Trans AM WS6
Transmission: TH700R4 Stock
Axle/Gears: 3.08 LSD
Your 89 GTA got the dual fan setup: primary and auxiliary fans.
Primary fan kicks on at 223 °F and off at 220 °F.
Stock thermostat opening temperature is 195.
Oil pressure seems to be a little low (about 21 PSI).Should be around 30 .BUT ABSOLUTELY NOTHING TO WORRY ABOUT!!!!!
