loss lots of power
Old Dec 2, 2014 | 10:25 PM
91z28camaro1996's Avatar
loss lots of power
Alright guys my 91 305 tpi been acting up had codes read but they were for a o2 sensor could that really cause my car to lose so much power that a 94 5 speed eg civic made me look like a sitting duck I also have full bolt ons
Old Dec 3, 2014 | 03:48 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: loss lots of power
You would be surprised how much of a roll some of the sensors sending information to the ECM play.
They all have to work together so the ECM can make adjustments.
Example = I broke the "little" plastic vacuum line going to the MAP sensor while changing the cap and rotor.
I figured OK Ill just drive to the local auto parts store to get some hose line but I wanted to see how the car would act without MAP .
My brother tried to start the car with me watching ,The air cleaner assembly
was still off.
When he turned the key I thought the car was exploding.
A tower of whatever the TBI could pump out shot up in the air.
Scared the s--t out of me.
So replace it and find out ....
Old Dec 3, 2014 | 07:23 AM
2005Impalla's Avatar
Car: 86 Z28 T-Top
Engine: Vortec 350
Axle/Gears: I think 3.73 open dif
Some cars have to have an O2 sensor to run proper. I had a 92 civic I pulled the O2 out off for 3 days and it ran fine but my brother in law had the O2 go bad in his late 80s Toyota truck and his fuel mileage dropped almost in half.
Old Dec 3, 2014 | 08:26 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
It all depends how the ECU is designed. Some have good calibration tables to fall back on in the case of a missing O2 sensor. Some will barely start. Stop racing your car and fix it properly.
Old Dec 3, 2014 | 08:34 AM
Really wasnt just playing with my friend
Old Dec 3, 2014 | 02:22 PM
FRMULA88's Avatar
Car: 1988 Formula
Engine: 421 Little M block
Transmission: TH400 w/brake
Axle/Gears: 9" 4.30s, Wilwood discs, 28X10.5-15
Without the 02 sensor, The ECM will default to "limp home mode"
performance is non-existent when the "service engine soon" light is on.
BRoss99
Aug 10, 2025 05:08 PM
theshackle
Sep 17, 2020 08:26 AM
transamgta1Khp
Aug 17, 2015 12:18 PM
tnrednneck
Aug 13, 2015 08:57 AM
Bradsaundry
Aug 12, 2015 12:34 AM
