Timing for 350 hsr t5 88 gta
Old Dec 8, 2014 | 09:48 PM
soarestransam's Avatar
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
Ok so im in the process of putting the distributor back in and im wondering about timing do i need to be right at 0 degrees or should i be 8 degrees btdc i know as long as u are in the 0-8 degree range the engine will fire up as long as the firing order is right am i correct or talking like i dont know what im talking about any help would be great
Old Dec 9, 2014 | 07:12 AM
Re: Timing for 350 hsr t5 88 gta
Will run at either. Prolly will run better at 8 BTDC.
Old Dec 9, 2014 | 08:20 AM
Engine: LR4 4.8
Ok so i was correct looks like ill go at 8 degrees btdc now when i drop the dizzy down where ever the rotor is pointing that's where no.1 spark plug will be hooked up to
sheachopper
Jul 31, 2019 11:27 AM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
bjpotter
Oct 4, 2015 07:48 PM
earlpote
Sep 12, 2015 11:55 AM
