Question of tbi to carb swap
Old Dec 19, 2014 | 07:22 AM
mac86's Avatar
Car: 1987 Camaro Z28
Engine: Carbed 355
Transmission: Borg Warner T56
Axle/Gears: 4th gen 10 bolt 3:73 Richmond gears
What do i need to do to swap my car from a tbi intake to a carb with a 4 brl carbuerator? Aside from intake gasket, intake, and carbuerator? What all needs to be done?
Old Dec 19, 2014 | 07:32 AM
Vader's Avatar
Re: Question of tbi to carb swap
How will the ignition timing be controlled? Since the stall saver routine in the fuel program will no longer be effective, will you be adding a dashpot? Will the EVAP system still be used? Will this be an auto-choke carb?
Old Dec 19, 2014 | 07:43 AM
mac86's Avatar
Engine: Carbed 355
I posted this to find all of that out. What is a dashpot, what is an evap, and the carb is an electronic choke
Old Dec 19, 2014 | 07:44 AM
mac86's Avatar
Engine: Carbed 355
The engine i have is a rebuilt 355 by the way, no emissions stuff on it
Old Dec 19, 2014 | 07:49 AM
mac86's Avatar
Engine: Carbed 355
This is what im buying to swap it to carb, Carb is edelbrock 2559 1406 electric choke 600 cfm carb, intake is an edelbrock performer 2101.
Old Dec 19, 2014 | 07:50 AM
mac86's Avatar
Engine: Carbed 355
I just need to know what else i will need and what else i need to do to do this right
Old Dec 19, 2014 | 08:26 AM
mac86's Avatar
Engine: Carbed 355
Okay so so far i found out that i need a vacuum advanced hei distributor, and a fuel pressure regulator, what else do i need?
Old Dec 19, 2014 | 08:58 AM
RamIt's Avatar
Car: 1984 z28
Engine: Crate replacement L31R 350
Axle/Gears: 7.625" 28 spline 3.23
Intake, carb, distributor, return style - low pressure regulator and possibly a higher capacity intank fuel pump if its making decent power.
Personally I prefer to have the evap (Evaporative Emission Control System) hooked up. I hate the smell of gas in the garage. It's the lines and equipment that capture the fuel vapors and route them to the engine to be burned off instead of being vented to the atmosphere. A open system can lead to your fuel tank rotting out early.
Old Dec 19, 2014 | 09:18 AM
Camaro86IrocZ's Avatar
Car: '86 Iroc Z & '91 RS
Engine: 305 TPI & 305 Qjet - Future LC9
Quick Question, where do you plumb this into a qjet setup?
Old Dec 19, 2014 | 02:25 PM
Night rider327's Avatar
Car: 1988 Camaro
Intake, carb, vacuum advanced hei distributor, mallory $95 fuel pressure reg., if still using 700r4 you will need a TV cable bracket and adapter kit,
Old Dec 19, 2014 | 04:00 PM
sootie007's Avatar
Car: 91 RS VERT
Engine: 305 9.67 2.02 58 cc 282 480 108 LC
Axle/Gears: 4.11 POSI
https://www.thirdgen.org/forums/carb...s-305-tbi.html
Old Dec 19, 2014 | 05:27 PM
mac86's Avatar
Engine: Carbed 355
Okay thanks guys, and it is a t56 no more 700r4
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
redmaroz
Aug 16, 2015 11:40 PM
cstrobel65
Aug 15, 2015 10:19 AM
