85 Wont Start!!
Old Dec 22, 2014 | 01:23 PM
at buckles's Avatar
85 Wont Start!!
I have a 85 camaro with a 305 the will crank but will not start. Sometimes it will idle for a between 5-10 secs but no more than that. Any suggestions on where to start?
Notes:
Fuel pump and filter are new so they area not clogged
No Codes
Thank you for any Help
Old Dec 22, 2014 | 01:58 PM
bigal55's Avatar
Car: 88 convertible
Engine: 5.7L
Transmission: 4+3 maual
Axle/Gears: 3.07
Re: 85 Wont Start!!
You need to tell a lot more info. What is fuel pressure? Do you have spark? Are the injectors firing? Was car running normal then suddenly won't start/run or did you replace/change/modify anything causing this to happen? An engine needs air, fuel and spark to run, eliminate the things you do have and go from there!
Old Dec 22, 2014 | 02:02 PM
bigal55's Avatar
Car: 88 convertible
Engine: 5.7L
Axle/Gears: 3.07
Re: 85 Wont Start!!
Rereading your post, I see you replaced the fuel pump and filter. Was the car not starting/running poorly before you changed these parts? Did you replace the pump with a high pressure pump for a TPI and not a TBI (lower pressure) pump?
Old Dec 22, 2014 | 02:05 PM
at buckles's Avatar
Re: 85 Wont Start!!
The car sat for about a about year and the fuel pump was replaced shortly before that.
Starts and then stalls with a little starting fluid (so I assume it has spark).
Injectors are firing (just tested with a noid light and it had pulse).
Old Dec 22, 2014 | 02:28 PM
at buckles's Avatar
Re: 85 Wont Start!!
Pump was replaced do to failure and the car was running normal after the fuel pump until it sat.
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
