spark plug removal with headers
Old Jan 15, 2015 | 09:28 PM
rrdogface's Avatar
Car: 1983 camaro
Transmission: a/t
Axle/Gears: ford nine inch
ok guys, this 85 350 has Hooker headers that cross directly over most of the spark plugs. Is there a special tool to get these out so I can replace them and ultimately the headers themselves? Thanks.
Old Jan 16, 2015 | 12:00 AM
Night rider327's Avatar
Car: 1988 Camaro
Re: spark plug removal with headers
5/8" open/boxed wrench
Spark plug socket with the wrenching hex on end, and wrench to fit that hex
Spark plug socket with a one side cut out (kinda like on a O2 sensor socket)
That's the 3 tools I use to change plugs with headers
Old Jan 16, 2015 | 12:59 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
I made one by welding a socket to a wrench BUT this seems to work well.
http://www.harborfreight.com/21-pc-s...set-67974.html
Make sure it has a curved handle.
Old Jan 16, 2015 | 06:02 PM
To add to night rider's list, which already has acoupla my favorites as well:
Box end wrench w about a 1" offset (can be made from a straight one by heating and bending)
Old Jan 17, 2015 | 03:16 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
I used an obstruction wrench I found in my late father's tool box. Took a bit of grinding as well as heat and bending. Fits right on the plug and I use it from underneath.
I have no idea how he ended up with a broken Craftsman wrench.
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Feb 28, 2016 03:33 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
