LT4 Hot Cam question
Old Jan 22, 2015 | 08:09 AM
Bricks34's Avatar
Car: '91 Camaro rs
Transmission: 5 speed
Axle/Gears: stock
I was wanting to put an lt4 cam in my 355 but on summit it's saying for the gen 1 blocks 1992-98 and my block is a 69-79. Now it's still a 2 piece and has a scat crank. Will if fit/work?
Old Jan 22, 2015 | 09:42 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Re: LT4 Hot Cam question
yes it will work if you are going with a roller lifter conversion kit as well. Unless there is something that Im missing.
Also you have to push the timing chain dowel further in. The cam has the longer dowl since it was designed for LT1/4 engines which had cam driven water pumps. Just push it in alittle, just leave enough for the cam gear.
Old Jan 22, 2015 | 10:39 AM
SR71BLKBRD's Avatar
Car: 92 Firebird, 91 GTA
Engine: 305 TBI, 350 TPI, * LS1 (Building)
certain manufacturers make similar cams with a option of the long pin or short pin. for example the Lunati 60121 cam im currently building my 383 with is a short pin.
Old Jan 22, 2015 | 06:05 PM
No, won't work, as-is.
Needs the retainer plate behind the cam sprocket, but your block can't accommodate that.
However you can get one of those, grind the "ears" with the bolt holes off, just slide it onto the cam nose before putting the sprocket on, and use a nylon cam button, which is soft enough you can whittle it down to fit among the sprocket bolts.
Then of course you'll need "retrofit" roller lifters.
I'd wizz-wheel the dowel off by about ¼".
MustangBeater20
Oct 29, 2022 09:20 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
anesthes
Aug 8, 2015 09:37 PM
