New Cardone distributor: Car wont start
Old Feb 1, 2015 | 07:35 PM
F-body driver's Avatar
Car: 1987 Trans AM WS6
Transmission: TH700R4 Stock
Axle/Gears: 3.08 LSD
Hello again guys
I am going to install a brand new distributor in my 305 TPI and time the engine
but, it wont start! I tried every top dead center, everything, but it wont
The first time I installed it the car fired up for 5-6 seconds then died
I pointed the distributor to the 1st cylinder, alligned the cap, and engine at top dead: nothing. Tried with the distributor at 180 (in the case I was on exhaust stroke): nothing. It seems there are not sparks in the chambers.
Coil seems good, injectors too, the ignition module is brand new (from cardone), spark plug wires are new (accel), ECM is new with hypertech chip.
Just in case I have the old ignition module from GM that worked like a champ
Please help me
Old Feb 1, 2015 | 10:30 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: New Cardone distributor: Car wont start
Did you make sure to mark the rotor position of the old one when you pulled it out?
You are positive you have the plug wires on the right plugs? It's easy to get those messed up, done it myself.
Old Feb 2, 2015 | 06:34 AM
Yes I checked wiring order many times! Unfortunately I cranked the engine over without the distributor so I have to time it again!
When I put the engine at top dead center on the compression stroke, will the engine start with this minimum advance?
Old Feb 2, 2015 | 08:30 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Yes, it "Should".
Provided everythign else is ready to fire over.
Just for grins, next time you fire over, put your old ECM back in (if it works), you might have received a bad ECM.
Make sure the flat four-wire is disconnected, with zero advanced, it should start. You'll want to get it to 6* BTDC as soon as possible though, that's close to where it should be factory.
Old Feb 7, 2015 | 11:24 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Originally Posted by F-body driver
Hello again guys
Please help me
NEVER buy anything "cardone" !! the absolute WORST Chinese POS I have EVER seen. well maybe a "airtex" fuel pump tops it, but not by much.
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
86Base
Aug 8, 2015 01:34 PM
L98GTA87
Aug 5, 2015 11:02 PM
