Hestiating While Cold: Solved
Car: 1985 Trans Am
Axle/Gears: 9 bolt Borg Warner Posi 3.27
I want to give everyone a heads up about a "hesitation while cold" problem I was dealing with.
Symptom was while first starting my 1985 LB9 305 TPI in the morning, I would have to let the car warm for 5 minutes or I would get hesitation and stalling while depressing the accelerator. Also, the car would (very rarely) suddenly shut off at random times. I was SURE it was a fuel issue, but it turns out the MSD HEI coil I had purchased new from Summit was defective.
I finally discovered the problem when the car would shut off after getting warm and then fail to start until it cooled down again. After it cooled, it would start.
The coil was replaced and the issues were completely resolved.
I hope this helps!
I hope this helps!
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Re: Hestiating While Cold: Solved
Good ole MSD!
Hopefully you replaced it with a stock coil .... ??
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
I hope this helps!
I hope this helps!
Engine: 4++,350 & 305 CIs
I have lost 4-5 MSD 6AL boxes and many of their older tpi style coils.
Have heard the quality has gone even further down hill..
Not a big fan of them
Car: 88 GTA Notchback
Axle/Gears: don't know
My car had an MSD coil on it when I bought it. After the distributor blew up, replaced it with a stocker and it has been good ever since. I NEVER have had good luck with any MSD products.
Car: 1985 Trans Am
Well, I didn't buy the "Street Fire" because I read nothing but bad things. I was under the impression that the real MSD stuff was good... I guess I learned my lesson!
Have a stock ignition system in now. Runs fine.
Thanks!
Thanks!
Pac J
May 17, 2020 10:44 AM
tyeo098
Nov 30, 2015 06:27 PM
