Sluggish acceleration- Solved
Car: 1992 Camaro
Engine: v6 3.1
Transmission: Automatic
No error codes other than 33, which I've had for over a year now. Sometimes causes stall outs, but very rare. I just changed spark plugs out three days ago. I gassed up a hoyr ago and twenty minutes later after a red light it started running strange. It's a throttley sound and accelerating isn't easy. Suggestions or ideas?
Edit: two of the spark plug wires' connectors came out while changing and I used two old wires I had from before. Those wouldn't be issue would they? It's run great for 3 days
Edit: solved. Thanks
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
Re: Sluggish acceleration
Sounds likes you have a dead misfire. Any of the wires rubbed through? Disconnected from the distributor cap posts? Disconnected from the spark plug? I've had them pop off due to the boot being a bit too long.
Edit: Just saw that you have a code 33. Yes this can cause all of the symptoms felt. Considering it's been this way for over a year, I'm leaning more towards the recent repair. The code 33 can be as simple as a cracked vacuum line from the MAP sensor to the manifold. This will cause a very rich condition and rough, lopey idle.
Car: 1992 Camaro
Engine: v6 3.1
Fixed. Double checked all the plugs and used a warranty at napa to get new plugs. Problem solved. Thanks.
Pac J
May 17, 2020 10:44 AM
tyeo098
Nov 30, 2015 06:27 PM
