Removing Stock Starter: Tip
Old Feb 16, 2015 | 11:54 PM
RED85TPI's Avatar
Car: 1985 Trans Am
Axle/Gears: 9 bolt Borg Warner Posi 3.27
Hey Everyone,
I read through many threads about removing the stock starter because I was replacing mine with a high torque mini starter.
After reading quite a few "just play with it", "drink a beer" and "remove the Y-pipe" tips... I decided to add my own tip that allowed me to remove mine in 10 minutes..
TAKE OF THE SOLENOID!!!
Remove the 15mm bolts that hold the starter to the engine, remove the wiring (one 10mm and one 5/16in) and remove the three small bolts holding the solenoid to the starter.
When its free, twist the starter clock-wise and pull towards the front of the car and let it fall between the a-arm and the exhaust pipe, nose up.
Be mindful of the temp sensor wire and the spark plugs.
Don't even attempt without first taking off the solenoid!!!!
Hope this helps!!
Old Feb 17, 2015 | 07:33 AM
FRMULA88's Avatar
Car: 1988 Formula
Engine: 421 Little M block
Transmission: TH400 w/brake
Axle/Gears: 9" 4.30s, Wilwood discs, 28X10.5-15
Re: Removing Stock Starter: Tip
You don't say. My life was incomplete until this very moment.
pssst hey did you hear... the earth is round !!! isn't that exciting!!!
Old Feb 17, 2015 | 10:48 AM
Barlow8869's Avatar
Car: 1989 IROC-Z / T-Top -1987 GTA
Engine: 305 (LO3) _350 (L98)
Transmission: 700R4 _ 700R4
Axle/Gears: 2.73 L.S. - ???
no need to do that ... it will come right without doing that ... nose up solenoid by the block
Old Feb 17, 2015 | 12:52 PM
whatever84's Avatar
Car: 84 Camaro
Engine: 357
Transmission: TH350
Axle/Gears: 4.10's / Strange LSD
Man I don't get all the sarcasm on this site, I'm sure alot of us know how to get a starter out but i'm sure he was just trying to give advice to someone who might need it, kinda thought that's what these kind of sites were for....
Mark.
Old Feb 17, 2015 | 01:33 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Mark.
"I decided to add my own tip that allowed me to remove mine in 10 minutes.."
Old Feb 17, 2015 | 02:00 PM
Barlow8869's Avatar
Mark.
i was not using sarcasm ... trying to save people some time and work
Old Feb 17, 2015 | 02:14 PM
whatever84's Avatar
Car: 84 Camaro
Engine: 357
Transmission: TH350
This was not directed at you..
Mark.
Old Feb 17, 2015 | 04:33 PM
RED85TPI's Avatar
Car: 1985 Trans Am
Yeah, I was just trying to help people out by giving a simple tip that will save time.
I was thinking of "feeding the troll" but it wouldn't do any good Some people just like being dicks. Perhaps FRMULA88 was having a bad day and needed vent!
Even if the tip helps one person save 5 mins changing a starter, I think its worth it.
NBrehm
Aug 25, 2015 11:49 PM
TheExaminer
Aug 25, 2015 07:34 PM
NinjaNife
Aug 23, 2015 11:49 AM
gta power
Aug 13, 2015 06:15 AM
3rdgenparts
Aug 8, 2015 07:09 PM
