Cam Chaft & Heads
Old Mar 1, 2015 | 09:01 AM
jtk821's Avatar
Car: 89 Trans Am GTA
Engine: 350 (355)
Axle/Gears: 3.45
Cam Chaft & Heads
Hey guys I have 2 questions that I would like opinions on. Currently I have a 89 Trans Am TPI. I swapped the 305 and put a 355 in it. Flat top pistons making high compression, and have the hookers headers, and intake all set on it. I am wondering though what would be the best heads to put on it so it can finally breath? Pretty sure it still has stock 1.80 heads on it. Also what is the biggest cam I can put in there that the computer will be able to read?
Old Mar 1, 2015 | 09:50 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: Cam Chaft & Heads
Sense you did not mention budget and you just want the best I would get arao 32V conversion heads
Old Mar 2, 2015 | 12:59 AM
34blazer's Avatar
Car: '86 Grand National
Engine: LZ9????
Transmission: 2004R
What's a cam chaft?
kidding.
Old Mar 2, 2015 | 08:28 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
This isn't a power adder topic.
Old Mar 2, 2015 | 08:49 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Look at a Lunati Lunati 20080721 (formerly 60121) or equivilent.
For heads, again, you didn't mention budget, but 195cc AFR's are probably the best but will run $2100 for the set.
gta90
Sep 15, 2015 04:00 PM
michealleger
Aug 26, 2015 03:29 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
anesthes
Aug 8, 2015 09:37 PM
