oil pump driveshaft loose?
Old Mar 6, 2015 | 09:25 PM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
Finally installed my melling is55e with the steel collar. I've searched around but just wanted to make sure it was ok. The driveshaft doesn't lock in place on the pump so when I install it in its hole it falls away from the pump. Will it be ok once the engine is back upright?
Old Mar 6, 2015 | 10:17 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: oil pump driveshaft loose?
Steel collars don't lock on like the OEM plastic ones do.
When the engine is upright, the shaft will fall onto the pump. You just need to make sure the distributor sits down far enough to engage into the shaft. Some white grease can help show how far down it sits onto the shaft.
Old Mar 6, 2015 | 10:34 PM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
Alright too easy
toronto formula
Nov 10, 2015 06:17 AM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
xxx3man`
Sep 23, 2015 10:37 PM
Navy8125
Aug 21, 2015 09:32 AM
