will a 92 tb 305 distributor work on a 92 tpi 305?
Old Mar 13, 2015 | 08:16 AM
CatmanFS's Avatar
Car: 85 Z28
Engine: 93 LT1
Axle/Gears: 3.73 01 SS
Title says it. Been wanting to die every time i put it in reverse or drive, read a thread that pinpointed the distributor as the problem. Any suggestions appreciated.
Old Mar 13, 2015 | 08:45 AM
CatmanFS's Avatar
Car: 85 Z28
Engine: 93 LT1
Re: will a 92 tb 305 distributor work on a 92 tpi 305?
Doesnt seem like tcc lockup, Comes to a stop just fine and can idle with brakes on and stopped. the timing might be just a hair off, but it idles fine and revs good.
Old Mar 13, 2015 | 12:19 PM
Formula 305's Avatar
Car: 1990 Formula Firebird
Engine: 305 TBI (LO3)
Transmission: WC T-5 out of an 88 T/A
Axle/Gears: 10 bolt, 3.42 & Torsen Posi
What is your base timing set at?
Old Mar 13, 2015 | 12:29 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Only difference is the module.
But it will work. Won't cause your problem.
Old Mar 13, 2015 | 04:18 PM
CatmanFS's Avatar
Car: 85 Z28
Engine: 93 LT1
Theres a thread on here about this. Same exact issue, they tried everything but it came down to the distributor. i have one from a 92 rs 305, and if timing it didnt help id swap that in and give it a shot. So just swap over the little icm module on the dizzy, and should be good ?
Old Mar 13, 2015 | 04:21 PM
CatmanFS's Avatar
Car: 85 Z28
Engine: 93 LT1
https://www.thirdgen.org/forums/tbi/346079-engine-dies-when-shifting.html
Check it out
Old Mar 13, 2015 | 04:23 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Unless the ign module is the problem.
Old Mar 13, 2015 | 04:26 PM
CatmanFS's Avatar
Car: 85 Z28
Engine: 93 LT1
but it idles fine, and drives good too. Shifts well, but when dropping it into reverse or drive it dies unless i rev it up a bit before hand
Old Mar 13, 2015 | 04:27 PM
CatmanFS's Avatar
Car: 85 Z28
Engine: 93 LT1
Does the icm have some connection to the trans shifting? Maybe like an retard to help drop into gear?
Old Mar 13, 2015 | 04:41 PM
CatmanFS's Avatar
Car: 85 Z28
Engine: 93 LT1
Ok, so i added some trans fluid last night, it looked low, and it was still doing same thing. just now i went to check it out and it kicked right into gear, no problems, drive or reverse. Guess it just took a while for the fluid to get through the converter and keep it from sticking and killing the engine. im going to give it a good tune up and set the timing correctly and that should be the last of it for now. Thanks for the replies, and i would still like to know more about what we talked about. Any info or suggestions appreciated. Thanks.
Old Mar 14, 2015 | 01:55 AM
rick90gta's Avatar
Car: 1990 GTA
Engine: 5.7L TPI SLP Runners Accel 24lb Inj
Transmission: 700R4 Upgraded Internals, Shift Kit
Axle/Gears: Borg Warner 9 Bolt, 3.27 Ratio
i had a bad coil connection once that would make a momentary misfire when the engine rocked (shifting into gear, accelerating) coil wiring could definitely cause it. found an almost broken off wire at the coil connector
Old Mar 14, 2015 | 09:10 AM
CatmanFS's Avatar
Car: 85 Z28
Engine: 93 LT1
Yeah im looking to replace the spark plug wires. I have a set Msd 8.5 high performance but the have the little metal contacts sticking out about a half inch on the dist side, for a different style distributor. Im looking to trade for a set that fits my car. Until then i just got to keep checking contacts and hopefully everything goes smoothly.
Fast355
Dec 2, 2016 06:33 PM
armybyrd
Dec 5, 2015 09:22 AM
st.evel07
Aug 13, 2015 06:15 PM
marcusaw
Aug 10, 2015 08:13 AM
drathaar907
Aug 10, 2015 07:44 AM
