Intakes under stock hoods?
Old Mar 13, 2015 | 03:13 PM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
What intakes would you guys recommend for a carbed L98 build under a stock hood. Would be looking to pull around 6000rpms give or take.
Old Mar 13, 2015 | 08:50 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: Intakes under stock hoods?
TPIS Miniram or FIRST Fuel Injection set up will be your best bet to replace the TPI and fit under the hood.
Old Mar 14, 2015 | 11:39 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
for a CARB motor ,the edelbrock RPM air gap is hard to beat. IMHO
Old Mar 14, 2015 | 11:57 AM
Ozz1967's Avatar
Car: 1984 Trans Am
best carb intake but he'll need a drop base air cleaner or the carb top will hit the hood.
Old Mar 16, 2015 | 07:50 AM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Thanks guys yeah I already have the drop base air cleaner on my TBI now im just wondering what carbed intakes yal like that can pull 5800-6000 rms. I couldn't remember what I used last time on my 350 vortec build but I remember having to use a 2in filter also I think.
Old Mar 16, 2015 | 10:17 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Then the RPM Air gap is the intake you want. 1500-6000 RPM range and is dual plane so good street manners.
Old Mar 16, 2015 | 01:20 PM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Thanks I have actually been looking at that one. Im starting to get my stuff together for maybe a build next year this time.
Old Mar 16, 2015 | 02:24 PM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
If you're using vortec heads the GMPP Vortec Eliminator is a good intake, doesn't fit under a stock hood though....it's also a single plane
Old Mar 16, 2015 | 03:02 PM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Im probably gona use iron L98 heads but if I go vortec again I think I had used a summit vortec intake last time that seemed to work well. Main thing is I will keep my stock hood but want to pull 5800-6000 rpm range.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
bryan623
Aug 10, 2015 11:33 AM
