Changing ignition cylinder quick question
Old Mar 14, 2015 | 03:33 PM
92Formula94's Avatar
To cut to the chase, keys got stolen. Got all new locks etc, everythings good there. Not im going to throw in the new cylinder, before I do I want to know the easiest way to get a key made. They include an OEM key that is a blank ready to cut. Id rather not have a locksmith out as they are expensive. Is there a code that comes in the kit that references how it should be cut? Who can cut it? I doubt depot or ace can cut a key for my ignition without having one to copy. Thanks guys!
Old Mar 14, 2015 | 04:02 PM
Re: Changing ignition cylinder quick question
I have another option, when my keys got stolen, I was about 130 miles away from where I live. No way is somebody going to track me down. I could use the original in the car already and have a key made up for it. Whats the cheapest route there? What do I need to go through a dealer etc. Also, whats up with this keylessrides.com. They say they would need to know my "resistance" to cut me a key. What do you guys think? Thanks.
car is a 92 formula 305 tpi 5 speed
Old Mar 14, 2015 | 06:50 PM
Was researching more, if I were to bypass vats I could go with any cylinder. Then, with the code that comes with the cylinder I could have the key cut. Where would I take the code and blank key to have it cut?
Old Mar 14, 2015 | 08:56 PM
Resolved my own issue, just bought another used cylinder that comes with the original key. Fixed
Old Mar 14, 2015 | 09:27 PM
greggbruce's Avatar
Car: 84 454 monte, 89 formula, 86 camaro
Engine: the bigger the better
Transmission: 700/4L60 in everything
Axle/Gears: wish they were all 4.10's or better
it will work as long as the key is the same resistance as your original
Old Mar 14, 2015 | 09:37 PM
disabled vats.
I was having issues with it anyways, spliced the two wires together and installed a switch so no one can steal my car if for some reason I do lose my key again
Old Mar 16, 2015 | 12:10 AM
Worked perfectly, thanks guys.
NinjaNife
Aug 23, 2015 11:49 AM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
