Fuel pressure regulator 1990 3.1L
Old Mar 21, 2015 | 03:33 PM
whatdayasay's Avatar
My manual says the fuel rail and the regulator are one unit and to not remove the regulator, but I see the regulator is sold by autozone. What's the scoop?
I think my regulator is bad.
Old Mar 21, 2015 | 06:33 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Re: Fuel pressure regulator 1990 3.1L
Autozone sells the spring and diaphragm tha goes inside the regulator which is located on the fuel rail. What makes you think yours is bad? I replaced mine because fuel was bleeding out of the vacuum port when I removed the hose indicating that I had a ruptured diaphragm. Give us a little more info. Thanks.
Old Mar 21, 2015 | 07:36 PM
The fuel pressure stays the same when I remove vacuum from the regulator. I believe the pressure is supposed to increase. The car wouldn't rev up, it would just die when punching the accelerator. For some reason the car won't stay running now. I accidently used plumbers solder on the ignition coils new electrical connectors, I wonder if that why it won't stay running. The fuel pressure was 42 psi with the car off and the key on. I put the old coil back on temporarily with no improvement.
Old Mar 23, 2015 | 12:29 AM
antares57's Avatar
Do you have the original injectors? If so, you may have to remove the plenum and ohm the injectors. All should be be in the 13 - 14 ohm range. Anything below that is probably bad. I had two that ohm'd in the single digits. Replaced all of them with a set from Southbay.
Old Mar 23, 2015 | 11:21 AM
I think the VATS needs to be bypassed before I take it to the next step. I checked the ohms last night and if i remember correctly i came up with 9.44 K and i think that means no. 14 bypass unit from ricks camaros.
MustangBeater20
Oct 29, 2022 09:20 PM
9192camaro
16
Feb 3, 2019 12:21 AM
wayshegoes
Aug 17, 2015 12:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
Kaweh
Aug 9, 2015 02:54 PM
