Ok pump pickup to pan clearance?
Old Apr 3, 2015 | 06:10 PM
Hello, Michael's Avatar
Car: 1987 Pontiac Firebird Trans Am WS6
Engine: SBC 350
Axle/Gears: 3.70:1 BW M78 9-Bolt Posi
I calculated my oil pump pickup to pan bottom clearance and I come up with something around .458". Am I ok with this clearance? I put a straight edge across the pan flange and measured to the bottom and I get 8.313". The block to pickup bottom depth is 8", maybe 8.063. Gasket is a one piece rubber gasket .177 thick. I'm not sure what oil pan I have cuz it came off another motor I bought but I'm guessing it's aftermarket. The pump is a Milodon high pressure high volume pump and the pick up is a Moroso deep sump for 8.25 pans.
Old Apr 3, 2015 | 11:47 PM
Night rider327's Avatar
Car: 1988 Camaro
Re: Ok pump pickup to pan clearance?
3/8" ( .375") to 1/2" (.500") is the target range with 7/16" (.4375") being about perfect.
So your .458" is great
Old Apr 4, 2015 | 01:18 PM
Engine: SBC 350
Cool. Thanks!
Dialed_In
Aug 20, 2015 01:45 PM
Winchester1094
Aug 18, 2015 10:23 AM
articwhiteZ
Aftermarket Vendor Review
Aug 18, 2015 07:26 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
