85 305 tpi timing marks
Old Apr 12, 2015 | 08:14 PM
wizarrd's Avatar
i 'm changing my timing chain set but i noticed that to have my rotor pointing at # 1cylinder with the exhaust stroke my cam mark is at 12 and crank is at 12 if i rotate the the crank to 12 and cam to 6 then my rotor is at #6 cylinder at the exhaust stroke is this correct? i remember doing sbc with the marks at 12 and 6 rotor at #1 and all was good ..realy need to hear from people that know the answer..thanks
Old Apr 12, 2015 | 09:39 PM
Re: 85 305 tpi timing marks
"Both dots up" is #1 firing.
"Dot to dot" is also #1 TDC, but it's NOT #1 firing. It's #6 firing, but #1 exh valve closing and int valve opening. We build em there because it's eeeeezier to see, then we turn em to "both dots up" to drop the dist in.
So yeah, what you're seeing, and doing, is EXACTLY correct.
Old Apr 13, 2015 | 11:06 AM
wizarrd's Avatar
ok so when the dots are at 6 and 12 what cylinder should the rotor be at 6 or 1
Old Apr 13, 2015 | 04:32 PM
Dot to dot (crank dot @ 12, cam dot @ 6) = #6 firing; so rotor should be toward 6
Old Apr 14, 2015 | 09:00 AM
FRMULA88's Avatar
Car: 1988 Formula
Engine: 421 Little M block
Transmission: TH400 w/brake
Axle/Gears: 9" 4.30s, Wilwood discs, 28X10.5-15
no need to remove the distributor to replace the timing chain.
just line up the dots.. remove the old timing chain / cam gear.. install the new set "dot to dot" and done. most important don't crank over the engine until you install the new set.
Old Apr 17, 2015 | 09:04 PM
wizarrd's Avatar
it's all done thanks for the help but i had to replace distributor new one plus my chain had skipped
midge54
Dec 27, 2019 04:14 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
Thirim
Aug 9, 2015 06:19 PM
