Brake Fluid Reservoir Lid Is Spongy
Old Apr 14, 2015 | 05:49 PM
GTA88's Avatar
On my 88, I just popped the the lid off the brake fluid to add a few ounces, and when I put it back on it doesn't have a nice snap or click sound. It's easy to pop it off again, too, not much resistance. No leaks, and brakes work fine. Leave well enough alone?
Old Apr 14, 2015 | 11:23 PM
apie2546's Avatar
Car: 86 Trans Am
Engine: 305 LB9
Re: Brake Fluid Reservoir Lid Is Spongy
There are 4 clips two on each side. One may have snapped. I just bought a new one and after adding new fluid it cracked coming off.. Stuff isn't made like it used to be
Old Apr 15, 2015 | 03:07 PM
GTA88's Avatar
Apie, thanks for answering. Yeah, I do have all 4 clips still good (except one which is half chipped off). But I found out what the problem was: the rubber mat on the bottom of the lid had somehow stuck to the metal tub when I took off the lid, and I didn't realize that was uncool. Once I stuck the rubber mat back in it's grooves on the bottom of the lid, where it's supposed to be, it worked like a charm. It made a nice snapping sound, and even a quisssshhk vacuum sound when I closed it up this time. Life is good once again with a fully sealed brake fluid reservoir.
Old Apr 16, 2015 | 12:22 AM
apie2546's Avatar
Car: 86 Trans Am
Engine: 305 LB9
Glad you got it figured out! I learned my lesson. The brand new auto zone quality one zipped the rubber and snapped in a month. Ugh!
83 Crossfire TA
Jan 3, 2016 01:26 PM
LittleFranks
Sep 17, 2015 12:22 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
RED85TPI
Brakes
Aug 31, 2015 10:29 AM
