1 piece rear seal,no roller provision
Old May 13, 2015 | 01:18 AM
KILLemALL's Avatar
Car: 77 Y82
Engine: W72
Transmission: Super T-10
Just found my first one out of a 92 pickup.What a kick to the sack.
Low miles from my uncles wrecked half ton.At worst I was expecting to have to drill the bosses.Blech,what a let down;-(
I have heard of these,are they common?
Old May 13, 2015 | 12:29 PM
cardo0's Avatar
Car: Fourth Gen '94 camaro
Engine: 350 Gen II
Transmission: A4
Re: 1 piece rear seal,no roller provision
Yep, mostly in trucks. Not many though and i think GM at some time stopped installing flat tappet cams in new cars/trucks all together (still used in their crate engines though).
Yea if u plan on running a large duration cam the roller is the way to go. Though with short duration cams the flat tappets dont give anything away to rollers though. How much cam u gonna run? BTW u can always install a solid roller cam while more expensive than a OEM roller swap its alot cheaper than a retro hyd roller cam.
Old May 13, 2015 | 10:08 PM
KILLemALL's Avatar
Car: 77 Y82
Engine: W72
I was just going to run a stock roller with a set of vortecs,it's for my old truck.The two front cylinders were full of water any way,pretty crusty."Free" never works out for me;-)
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Reborn756
Sep 4, 2015 03:42 AM
LT1Formula
Aug 20, 2015 09:36 PM
Exxon Limited
Aug 9, 2015 08:13 PM
