Bad hei coil?
Old Jun 1, 2015 | 11:17 AM
happyhapka's Avatar
Car: 1986 Trans AM WS6
Engine: 383 Vortec TPI, PUTS SMILES ON FACE
Transmission: PATC LVL 3 Raptor Transmission
Axle/Gears: 3.27 POSI 9 BOLT
Bad hei coil?
1986 LB9 trans am
First of what happens
Was headed home from doing some running around and she just died but came back(more like a surge)/
Than anything from 1/4 -3/4 throttle is dead but re-catches herself .. Timing and fuel pressure is good. Module is good tps is good but I did notice a burn pop mark (like. The one you see when a fuse blows) on top of the coil in the corner next to cylinder 6.. Also the actual could is slightly melted.. But I noticed the cap had wetness in the terminal groove under the cap. It is a hypertech performance cap and rotor... And sometimes she starts OK and idlea and other times Shea running on 7 or 6 cylinders .. But sometimes comes back....
I think that's the problem but won't know for sure if that is the problem. But maybe you guys can tell me.
Old Jun 1, 2015 | 11:31 AM
happyhapka's Avatar
Re: Bad hei coil?
Forgot to mention it has been all wet and raining the past week
morrow
Jan 13, 2024 12:29 PM
86CamaroDan
Sep 29, 2015 10:08 PM
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
Blue419
Sep 10, 2015 01:03 PM
Stryker412
Sep 7, 2015 09:11 AM
