Halp! Can i rebuild this LG4 vacuum harness myself? Its impossible to find.
Old Jun 4, 2015 | 01:17 AM
KNIGHTE's Avatar
Car: 1985 TA http://bit.ly/1EadkbO
Engine: 5.0 V8 LG4 BBL
Transmission: 5 Speed Manual
This harness is so hard to find, and its broken in several places. The elbow connectors don't come off, so they cannot be replaced, and the thing with the double pipes going into it, well, i don't even know what that's called.
I've looked over amazon and ebay, but i am not sure what parts i can use to rebuild this.
Any ideas?
Old Jun 4, 2015 | 01:32 AM
iroczracer07's Avatar
Car: 1989 Camaro
Engine: 350 but it's torn down right now.
Axle/Gears: I'm working on it,lol.
Re: Halp! Can i rebuild this LG4 vacuum harness myself? Its impossible to find.
if they're all plastic then yes. Get the proper size line and use a little bit of heat on the line to make it pliable so you can shape it. plug it into the big rubber fittings and you're done.
Old Jun 4, 2015 | 05:43 AM
Restrorob's Avatar
Car: 88 GTA
Engine: Built 355 to install
Transmission: Built turbo 350
I've used windshield washer hose and a vacuum hose T, they don't have to be hard lines.....
Old Jun 4, 2015 | 06:15 AM
The thing with the 2 pipes doesn't really have a name.
Doesn't have to be replaced by a thing with both pipes in it; 2 individual ones work fine. Only reason the factory did it the way they did was to make it faster to assemble.
You can get every piece needed to replicate that functionally, even if not looking exactly the same, at about any parts store.
Old Jun 4, 2015 | 11:49 PM
KNIGHTE's Avatar
Yup - its all plastic! I'll try and give it a go.
Old Jun 9, 2015 | 08:56 PM
KNIGHTE's Avatar
Update!
Built this myself using regular hosing.
Passed smog!
Old Jun 10, 2015 | 09:54 PM
Car: 1989 Camaro
Infested
May 22, 2018 11:56 PM
Magman
Sep 13, 2015 08:43 AM
fbirdroller
Sep 2, 2015 10:27 PM
someone972
Aug 30, 2015 12:52 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
