87 305 carb wire question.
Old Jun 13, 2015 | 08:30 PM
orown87topless's Avatar
I have a 2 prong wire connector (weather pack) that is located behind the left valve cover. My wiring diagram says it is a vss bypass. It has a pink/blk and a black wire. Any idea what this is for and should it be plugged in somewhere ? It is too short to go to trans.
Old Jun 13, 2015 | 10:25 PM
Re: 87 305 carb wire question.
It goes nowhere.
Pink/blk = ECM power
Blk = gnd
Nobody out here in Internet land knows what it's for; but, being as how it's power and ground, what it could very easily do is, supply power to the entire engine, ECM, etc., without there being a car present.
I.e., a production-line test harness connector.
Don't worry about it. It doesn't go to anything now that the car has been built.
Old Jun 14, 2015 | 03:15 AM
Thanks for the info. I am chasing an est problem. The timing remains fixed and I am going thru the entire harness to eliminate potential sources. I have a new dist installed as well as a new module. Knock sensor is next. Anyone run into this issue before?
Old Jun 14, 2015 | 03:45 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Is your ECM fuse good?
Is your EST wire next to the distributor good and connected?
Old Jun 14, 2015 | 08:54 PM
will check.
midge54
Dec 27, 2019 04:14 PM
Infested
May 22, 2018 11:56 PM
Jae992
Aug 27, 2015 09:07 AM
tero
Aug 15, 2015 02:47 PM
