idle hunt only on cold start up
Old Jun 16, 2015 | 07:12 PM
89 formula TPI's Avatar
Engine: LB9 5.0L TPI
Axle/Gears: 9-bolt Borg Warner, 3.45
as the title states, when i start my 89 Formula 5.0 TPI up after it's sat overnight, the idle hunts all around...i turn the key and it will turn over but it will stutter a little around 700 rpms and then rev all the way up to like 2000 for a few seconds...come back down to like 700, stutter a little more and rev back up to 2000. eventually i'll intervene and press the gas for a little while and it calms down and settles down around 750. after that it's totally and completely fine. car runs and idles great.
any thoughts on possible causes?
Old Jun 18, 2015 | 07:30 PM
Re: idle hunt only on cold start up
noone else has heard of this issue? a friend suggested it could be my air/fuel mix is not correct at start up...any thoughts on what could cause that? can't be 02 sensor because it's still in open loop...i have a new MAF sensor and TPS sensor and cleaned out the IAC.
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
