89 Iroc 350 TPI won't start
Old Jun 13, 2015 | 06:10 AM
Jimmy R's Avatar
Car: 1989 IROC-Z
Engine: 5.7 TPI
Transmission: 89 Corvette option tranmission
Hey guys
My car ran fine Thursday ( 06/11/2015). Went to start it Friday ( 06/12/15) when I got home and "nothing" no cracking, just nothing. like starter is disconnected.
Battery is good, power to everything else, but nothing to engine/starter. It's the original starter in the car I'm thinking the starter, and or solenoid died and that's the issue. Been so long since I've had to deal with any issues with this car I don't remember.
Any suggestions ?
Jimmy R
Old Jun 13, 2015 | 11:37 AM
ex-x-fire's Avatar
Re: 89 Iroc 350 TPI won't start
Take a 12v test light that is hooked to ground and test...
The large starter wire, it should have power all the time.
The small starter wire, it should have power only when cranking.
Old Jun 13, 2015 | 12:06 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Tap on starter, make sure the cables are clean and tight.
Old Jun 16, 2015 | 08:04 AM
Jimmy R's Avatar
Car: 1989 IROC-Z
Engine: 5.7 TPI
ok
Starters been ckd no Pwr to starter, where now, guys?
Old Jun 16, 2015 | 07:13 PM
ex-x-fire's Avatar
Is the security light flashing?
Check the fuses, one of them is a 5 amp fuse labeled crank. Then you need to check the park/neutral switch.
Old Jun 16, 2015 | 07:50 PM
spurgeon76's Avatar
Car: 1989 IROC-Z
Axle/Gears: 4th gen rear with 3.42
If the Security light is coming on its the VATS
Old Jun 18, 2015 | 11:09 PM
gm muscle's Avatar
Car: '89 Iroc-Z
Engine: 5.7 TPI
Transmission: 700 R4
Axle/Gears: 2.77
Man, the dreaded VATS. Even if so, you can find how to get around it on this forum. Just search VATS. Shoot, YouTube has videos on how to get around it.
Old Jun 18, 2015 | 11:59 PM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
If its auto make sure its in park or the switch on the shifter is engaged in park if not then it wont start
armybyrd
Dec 5, 2015 09:22 AM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
wruiz
Aug 13, 2015 09:07 PM
gta power
Aug 13, 2015 06:15 AM
