Issues with my fuel tank installation
Old Jun 17, 2015 | 09:01 PM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
I took my tank out so I could install the new pump and the anti-squeak strips were shot. What did you guys use, or would recommend, to replace them?
Old Jun 17, 2015 | 09:04 PM
mk1431's Avatar
Car: 89GTA Black, Black cloth
Engine: LB9 26,000 miles
Axle/Gears: 3.45 Australian 9 bolt
Re: Issues with my fuel tank installation
def. change while out
Old Jun 18, 2015 | 03:53 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
back in the olden days (early 90's) we'd use old bicycle inner tubes for stuff like this, but i'm sure you can spend a lot of money at a restoration place if that makes you feel better.
Old Jun 18, 2015 | 05:42 AM
Elthesh's Avatar
Car: 1991 Pontiac Trans Am
Without looking it up, I either bought a repro set on ebay for a 67-69 firebird or one for a 70-81. Anyway, even though it was for the wrong years it still worked fine. I forget if they could use it as is or trimmed it any. I think they said it was fine as is. Or you could buy the factory set I just saw on ebay a second ago when I went looking to see what I bought, lol.
Also, after looking it was the 67-69 set I bought.
Old Jun 18, 2015 | 11:53 AM
jharrison5's Avatar
Car: '87 IROC
Ya there is no way I would have put the tank back in without putting strips on it. That thing was a pain to get out and I don't want to have to do it again not to mention the safety aspect.
I ended up going with a set of GM resto ones I found on eBay for $18.
Old Jun 18, 2015 | 12:25 PM
novaderrik's Avatar
Car: 86 Camaro
there really is no "safety" aspect- once you tighten those straps down, the tank simply does not move at all.. GM put them there to dampen noise from the tank.
Old Jun 18, 2015 | 12:40 PM
jharrison5's Avatar
Car: '87 IROC
I figure if they were there from the factory then there must be a purpose for them Lol! Also if I didnt replace them then Im sure a hole would get rubbed in the tank somehow since thats how my luck works out...
Frozer!!!
Jan 19, 2024 04:55 PM
Infested
May 22, 2018 11:56 PM
mustangman65_79
Apr 14, 2017 05:37 PM
justin57
Aug 20, 2015 07:05 PM
kyleb24
Aug 15, 2015 08:24 AM
