Car won't stay running
Old Jun 22, 2015 | 11:11 PM
Dustin250r312's Avatar
My 89 camaro won't stay running for some reason it was out of time before and now that it is in time it wants to die out when I give it gas and if I get it to run going down the road for about a min it will then backfire like crazy and die could this be the tps going bad? I'm at a loss with it
Old Jun 23, 2015 | 06:21 AM
Re: Car won't stay running
Put the timing back wherever it was.
It can be a humbling thing sometimes; but, Rule #1 of situations like this is, if you do something to your car and it runs worse than it did before, then you effed it up. Your work is the first thing to check.
Old Jun 23, 2015 | 12:21 PM
If i put the timing back 180 it won't run at all it will stay running right now just when I give it gas it dies out
Old Jun 23, 2015 | 06:15 PM
OK, so this setup (whatever it is) has never run right?
That's different from, adjusting the timing on a whim or whatever, and it commences to screw up.
Old Jun 23, 2015 | 09:45 PM
Well turns out that the tps fell off cuz the studs were broke and the guy I got it from glued it or put silicone on it so got it fixed for now until I get new studs for it
RazorN8
Jan 7, 2022 11:44 AM
justin57
Aug 20, 2015 07:05 PM
Kaweh
Aug 9, 2015 02:54 PM
Sherpajames
Aug 7, 2015 06:56 PM
