Engine cuts out in hard turn with low fuel
Old Jun 30, 2015 | 08:42 PM
cbrcrx's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: Manual
Axle/Gears: ?
This may have been talked about, but I couldn't find anything. My car is a 92 RS V8. If I have less than half a tank of gas and corner hard my gas gauge drops to empty. If I try to give it a lot of gas, it will stall from not getting fuel until I let off. Does anyone else have this? If so, is there anything to do besides keep the tank full?
Old Jun 30, 2015 | 10:49 PM
Poseidon's Avatar
Car: 1991 Firebird
Engine: 305 tbi Stock
Axle/Gears: 2.73 posi
Re: Engine cuts out in hard turn with low fuel
pull the tank and replace the rubber hose on the pump its sucking air once it gets low mine did same i just swapped new pump and rubber while in but my pump was good
Old Jun 30, 2015 | 10:57 PM
cbrcrx's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Axle/Gears: ?
Did yours do it only when turning fast too, or any time it was low on gas?
Old Jul 7, 2015 | 03:36 AM
thatsupnow's Avatar
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
Well obviously with low fuel that will happen cause it's all sloshing over to one side. These cars have small tanks and you really shouldn't let it go below half tank. It'll save your pump in the process too by keeping it cool
Azrael91966669
25
Jun 20, 2017 04:04 AM
theshackle
Mar 5, 2017 06:37 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
novaderrik
Aug 10, 2015 12:44 PM
