92 Camaro RS V8 No Crank Problem
Old Jul 9, 2015 | 07:44 PM
92CamaroDriver's Avatar
New member here. I have looked through tons of forums to look for a solution to my problem and haven't found any yet so here is my problem. This car was my daily driver to work. It started having problems starting after awhile but then it finally just didn't start. I turn the key and there is no click and doesn't crank. I have replaced the starter, ignition switch, starter relay, and battery. The security light comes on when I try to start but turns off after a few seconds so I can say with 95% assurance that the VATS is not an issue. I still may be wrong. I have tested the neutral safety switch as well by connecting the Green and Purple wire together, no crank (put back to original wiring). I have also tested the starter relay by connecting the Yellow and Green wires together, no crank (put back to original wiring). I have voltage going to the starter. I ran a jumper cable from the starter to the positive of my battery and it cranked. The only thing I haven't been able to get to is the ignition lock cylinder because of the steering wheel column having a metal plate inside that I can't get off to get to the cylinder. Is this something I need to check/test for a possible problem? Is there something else that I am not thinking of to check?
Old Jul 9, 2015 | 11:38 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: 92 Camaro RS V8 No Crank Problem
Do you have interior lights when you open your doors and dash lights?
Old Jul 9, 2015 | 11:54 PM
Yes. All lights work.
Falcon50
Aug 22, 2020 03:26 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Luigytico09
Oct 1, 2015 08:46 AM
ironbmt
Sep 27, 2015 06:00 AM
383cam
Sep 9, 2015 06:01 AM
