Whine then hissing after turning car off (video)
Old Jul 16, 2015 | 09:53 AM
L98GTA87's Avatar
Car: 1987 Trans am
Engine: 350 Vortec Stealth Ram
Axle/Gears: 02 SS Torsen Zexel 3.42
Can anyone help me with this sound? Happens as soon as I turn the car off. I have AC and usually run it but this morning I didn't for the purpose of this video. Makes a whine noise that fades out into a hissing sound then it's gone. Sounds like it's coming from the rear of the intake area.
Old Jul 16, 2015 | 04:14 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: Whine then hissing after turning car off (video)
I would've guessed ac. I would get a stethoscope and see if I can pinpoint the area.
Old Jul 16, 2015 | 08:56 PM
mk1431's Avatar
Car: 89GTA Black, Black cloth
Engine: LB9 26,000 miles
Axle/Gears: 3.45 Australian 9 bolt
LOL thats crazy never heard something like that
Old Jul 17, 2015 | 07:24 PM
Vader's Avatar
Could be a vacuum leak. The vacuum reservoir is supposed to retain vacuum beyond the check valve, but if something is leaking that might be the result.
Old Jul 17, 2015 | 10:01 PM
L98GTA87's Avatar
Car: 1987 Trans am
Discovered I have just shy of 90 psi in cylinder 4 during compression test. Haven't found what that noise was, but wondering if this could be a cause? I'll plug off all vacuum at the intake to bypass the HVAC and what not, see if that is it.
Old Jul 19, 2015 | 09:30 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Sounds like normal equilization of the a/c system to me, but I couldn't watch the video. My Express van squeals, hisses and you can hear the liquid refrigerant boiling out of the evaporator for a good minute after you shut it off.
Old Sep 14, 2015 | 08:09 PM
L98GTA87's Avatar
Car: 1987 Trans am
Just wanted to update. I have since swapped to a vortec 350 with stealth ram and don't hear this anymore. When I tore the engine down, almost half the pistons had broken ring lands. That may have had something to do with it.
specialized
Jun 18, 2022 09:26 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
