Lifter question
Old Jul 26, 2015 | 10:03 PM
Rob's 92 gta's Avatar
Car: 92 firebird gta
Engine: L98 with minor mods.
Lifter question
I just bought a comp xfi 280 cam and was wondering if the Chevy performance roller lifters for 305/350 Ls1,Ls2 and Ls7 will work for the cam I have.
Old Jul 26, 2015 | 10:28 PM
cardo0's Avatar
Car: Fourth Gen '94 camaro
Engine: 350 Gen II
Transmission: A4
Re: Lifter question
I believe so - if its an hyd roller cam. I think whenever u buy GM roller lifters now u get the LS7 roller lifter. I thought they had a different preload requirement but now find they dont. Thought i had read an instruction for the LS7 lifter saying that but cant locate it now. I did read the lifter cup & plunger/piston travel was increased but u can google that for yourself.
Aftermarket hyd rollers with the Link-Bar are expected to be used in higher rpm engines. Also the stock hyd roller lifters have a smaller roller thats somewhat shrouded - i think the larger the roller the faster the lifter accelerates up the lobe ramp for a little more flow area.
Hope this helps more than it confuses.
Old Jul 26, 2015 | 11:34 PM
Night rider327's Avatar
Car: 1988 Camaro
Re: Lifter question
What is the cam part #? If it is a hyd. roller cam to be installed in a factory 1987 and up roller cam engine block, then yes the GM performance stock roller lifters will work.
If it is a retro fit roller cam to be used in a 1955-86 block, then now those lifters will not work
Old Jul 27, 2015 | 02:19 PM
Re: Lifter question
Thanks for the help I will.check that out.
Old Jul 27, 2015 | 02:22 PM
Re: Lifter question
It is a roller motor it is a.92 L98 GTA. Thanks for the help.
beastin91rs
Oct 9, 2015 07:38 AM
Mickeyruder
Sep 2, 2015 02:45 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
Cameeeero
Aug 20, 2015 03:06 AM
redmaroz
Aug 16, 2015 11:40 PM
