Running rich
Old Jul 30, 2015 | 12:06 AM
thorflynn15's Avatar
Car: 1987 IROCZ28 Camaro
Running rich
Replaced MAF sensor and MAF relays, replaced O2 sensor, did a plug, cap, rotor, wire tune up, still running rich. Don't really know where else to look besides the ECM. Any ideas? Need to pass inspection
Old Jul 30, 2015 | 06:17 PM
ex-x-fire's Avatar
Re: Running rich
Check for high fuel pressure or fast bleed down rate.
Old Aug 2, 2015 | 01:00 AM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
Re: Running rich
Is there a check engine light? EGR can make a car run rich as well as an o2 sensor. so can a vacuum leak. Since it's a maf car, any vac leak after the maf sensor is unmetered air going into the motor, the ecm picks up on this lean condition and starts adding more fuel to compensate for the extra air causing it to run rich.
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
tmellott89
Aug 16, 2015 02:58 PM
squiggy2
Aug 9, 2015 09:30 PM
