Idle after long uninterrupted drive
Old Aug 10, 2015 | 07:22 AM
zeitghaist's Avatar
Car: 1989 Trans AM
Transmission: TH700R4
Hi!
I'm currently hunting the last engine problem after the major tune up (which worked wonders )
When I drive a longer trip over for example the highway and get to the first traffic light my Firebird won't hold the idle and nearly/go out suddenly. This never happens in the city and doesn't seem connected to the temperature or something...
Afterwards if I restart the engine the problem just disappears (sometimes I need a second restart at the next stop)
Any ideas what could cause this?
Old Aug 11, 2015 | 05:44 PM
legendaryhero7's Avatar
Car: 91 Camaro RS
Engine: 3.1 v6
Re: Idle after long uninterrupted drive
Do you ever have stuttering acceleration or coasting in lower rpms? Something similar was happening to mine, and it turned out to be the throttle position sensor.
Old Aug 18, 2015 | 02:39 AM
zeitghaist's Avatar
Car: 1989 Trans AM
Sorry for the late answer, nope, no stuttering, I had this issues a lot but got rid of them thanks to new spark plugs etc.
I've measured the tps some time ago (was also my main suspect for the rough idle) but it all checks out voltage wise...
Old Aug 18, 2015 | 07:20 AM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
Bad EGR valve? During the highway cruise it gets activated, then hangs open for a bit, displacing the idle mixture. Then when the engine stalls or during the restart, the valve manages to close.
Old Aug 18, 2015 | 07:33 AM
zeitghaist's Avatar
Car: 1989 Trans AM
Hmm That could be it!!!
Thank you, I will try to clean it! (If I find some instructions for that, alternatively I will get a new one)
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
Wade787b
Sep 29, 2015 01:15 PM
86White_T/A305
Aug 17, 2015 12:16 AM
