Cam thrust plate bolt torque
Old Dec 19, 2001 | 02:43 AM
PerthZ28's Avatar
Does anyone know the spec for the roller cam engine cam thrust plate bolts [2 of the little buggers]?
Old Dec 19, 2001 | 04:47 AM
PerthZ28's Avatar
NE1 know of a site that lists engine bolt torque specs??
Old Dec 19, 2001 | 07:42 AM
Nitroburn's Avatar
I believe it is listed as a Camshaft Retainer Plate and it's listed at 9 ft. lbs. (or 12 Nm).
Hell, I hope that what it is because that's what I just set mine at two days ago!!
Old Dec 19, 2001 | 09:21 AM
fast_broker's Avatar
9 is close enough and be sure to clean the bolt and hole with a cleaner/degreaser and then use RED loctite before assembly.
LT1Formula
Nov 16, 2015 01:13 PM
camaro71633
Sep 1, 2015 10:24 AM
86White_T/A305
Aug 17, 2015 12:16 AM
gwade12
Aug 8, 2015 08:17 AM
