1989 Camaro Iroc won't turn over
Old Aug 15, 2015 | 09:11 PM
Derick15's Avatar
I bought a 1989 camaro iroc 305 5.0l. It sat for 4 years. I went through and replaced plug wires, new gas, air filter, oil, oil filter. Installed a brand new battery. I have a brand new distributor, rotor and coil. I go to start the car and it doesn't turn over. Headlights come on, gauges flutter, just won't turn over. The starter got tested, it does work. I have no idea what it could be. HELP PLEASE
Old Oct 6, 2015 | 05:50 PM
Piston454's Avatar
Car: 1990 RS Camaro
Engine: 400 sbc throttle body
Transmission: world class t5 manual
Axle/Gears: 3.73's, Detroit TrueTrac
Re: 1989 Camaro Iroc won't turn over
check you ignition tumbler. when you turn the key all the way forward with out trying to start it, look at your warning lights on your dash and see if the "security" light is on. if it is on then one of (or both) wires in your tumbler is broken and it wont close the "VATS" loop to allow it to start. you will either need to splice the wires back together or get a new tumbler. those two wires read the resistance in the chip thats in your key and it cant read it if the wires are broken. my car did the same thing.
Old Sep 17, 2016 | 05:28 PM
smokehouse's Avatar
. Hello I'm a new user that has 1989 Kroc with 5-7 that will turn over but not start. It have a very weak spark. Any help?
camaro11j
Sep 19, 2018 08:49 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
Rustyweb7
Aug 9, 2015 03:05 AM
