Backfire and Black smoke what do I do?
Old Aug 18, 2015 | 06:10 PM
Red iroc-z 305's Avatar
Car: 1985 Camaro Iroc-z
Engine: 4.8 Ls
Transmission: 4l60e
Axle/Gears: 342 10 bolt
Hey guys, I recently purchased a 85 Camaro Iroc-z, I changed the injectors, timed the car, checked if I had spark, and changed the spark plugs. All those things passed as I checked and replaced them. I finally started the car and at idle the car would backfire. Mind you I timed my car to where it was supposed to be so nobody ask "Did you time the car?" Also, as car is in idle a lot of black smoke was pouring out of back pipes, as time went by it was not as bad but car still smoked. If you guys could help me out with answering my question of why these things are happening that'd be great.
Old Aug 18, 2015 | 08:17 PM
mdtoren's Avatar
Car: 1986 Iroc Z28
Re: Backfire and Black smoke what do I do?
I'm no pro by any means but it sounds like your idling way too rich, have you checked the tps and reset the iac? Your idle could be set for your old, potentially weak/clogged injectors so when your new injectors started firing, they were dumping way more fuel than your idle air was set to handle..just a thought.. You never know what previous owners put bandaids on.
Old Aug 18, 2015 | 08:34 PM
Engine: 4.8 Ls
Transmission: 4l60e
Thanks for responding, yes we checked the tps, but we have not checked the iac I will give you updates on how it goes thanks!
Old Aug 19, 2015 | 12:19 PM
Engine: 4.8 Ls
Transmission: 4l60e
Well we reset the iac but the backfiring has not stopped as well as that the car still smokes does anyone have any suggestions on what to do?
Old Aug 21, 2015 | 12:21 PM
Engine: 4.8 Ls
Transmission: 4l60e
Well everybody I did some research and found that my coolant temperature sensor was no good and was putting way to much gas into my engine, there still is a tiny misfire and a tiny bit of smoke but only happens when I rev the engine, if you guys have any ideas of how to fix that permanently give me a shout, other than that thanks for the help!
Old Aug 21, 2015 | 12:35 PM
-=Z28=-'s Avatar
Car: 84 Z28
Engine: 383 Stroker
try to get it to shudder/misfire, and shut it down right away, (so that it doesn't clear up the plug), then pull plugs and see if one is booger-ed up. May tell you something or not. Your positive you have the correct plugs/gap?
All the injectors firing?
Old Sep 30, 2015 | 03:28 PM
Engine: 4.8 Ls
Transmission: 4l60e
Yea there all firing, and the timing was off a little so the smoke is gone, and there is a tiny misfire but it seemed to go away after the timing was changed. Thanks for the help!
Old Sep 30, 2015 | 03:34 PM
UltRoadWarrior9's Avatar
Car: 1986 IROC Z-28
Engine: 383 Gen I SBC 11:1
Transmission: Rebuilt TH700R4 for 500+HP
Axle/Gears: 4th Gen 10 bolt Eaton Truetrac 3.23
Originally Posted by Red iroc-z 305
Hey guys, I recently purchased a 85 Camaro Iroc-z, I changed the injectors...
Changed the injectors? Why?
Old Sep 30, 2015 | 05:22 PM
Engine: 4.8 Ls
Transmission: 4l60e
The injectors were bad when I bought the car.
gta892000
Aug 11, 2019 11:16 AM
Fronzizzle
Feb 9, 2017 09:31 AM
m00n420
Sep 11, 2015 02:39 PM
Accerrito22
Sep 5, 2015 09:34 PM
Out-Cast
Canadian Region
Sep 4, 2015 10:13 AM
