Huge nut! Where does this go?
Old Aug 19, 2015 | 09:01 PM
86IROC112's Avatar
Car: 1986 IROC Z
So I had to jack the car up to get under there and disconnect my exhaust from my manifolds and found this sucker on the ground near the front driver's side wheel. Kind of concerns me before I take it on it's maiden drive.
What the hell could this go to?
Old Aug 19, 2015 | 09:07 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Re: Huge nut! Where does this go?
LCAs?
Old Aug 19, 2015 | 09:09 PM
86IROC112's Avatar
Car: 1986 IROC Z
Originally Posted by antares57
LCAs?
LCAs?? Not familiar with that one..
mjdavis68's Avatar
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
Pitman Arm
Old Aug 19, 2015 | 09:11 PM
86IROC112's Avatar
Car: 1986 IROC Z
Originally Posted by mjdavis68
Pitman Arm
Oh S##t, not good..I will check it out..
Old Aug 19, 2015 | 09:12 PM
antares57's Avatar
Lower Controls Arms under the front springs, while '68 above may be closer.
Old Aug 19, 2015 | 09:18 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Maybe the pan hard bar
Old Aug 19, 2015 | 09:53 PM
86IROC112's Avatar
Car: 1986 IROC Z
Pan hard bar?? I spent so much time learning the engine I don't know much about the underside. I would guess there should be one just like it on the other side?
Old Aug 20, 2015 | 02:53 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
the only nut on the whole car that looks anything like the one in the pic is the one that holds the Pitman arm onto the steering box. but this looks too thick for even that. the one that holds the u joint flange to the pinion gear on the rear end looks similar, but slightly different.
i'd say that it was on the ground when you parked there.
Old Aug 20, 2015 | 03:25 AM
Twin_Turbo's Avatar
Yup it's from the pitman arm. Those arms are pressed on very yight. Just put the nut back on and tighten it good.
Old Aug 20, 2015 | 09:36 AM
86IROC112's Avatar
Car: 1986 IROC Z
Will do. You think they'd put a cotter pin in something like that..Thanks
Old Aug 20, 2015 | 12:18 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
It should have a equally huge lock washer on it.
timonator
Sep 30, 2015 12:52 PM
gord327
Sep 29, 2015 10:18 PM
3.8TransAM
Sep 27, 2015 08:37 PM
apie2546
Sep 24, 2015 12:27 AM
Fox118
Sep 12, 2015 09:29 PM
